set UART speed
How could I set write UART speed?
I'm opening /dev/uart1 device via fopen().
SOPC builder just do not have speed option.
I'm using Nios IDE 9 and Quartus 9 and Nios II dev kit EP2S60 RoHS.
Soemthing via IOCTL?
You have two possibilities to set the baudrate in UART.
Either at system generation time and you cannot modify it after, or in SOPC Builder you check "Baud rate can be changed by software (Divisor register is writable)". And you can modify the baudrate in software by writing into the divisor register.
The formula between this register and the baudrate is in Quartus Handbook Volume 5 page 6-4 (http://www.altera.com/literature/hb/nios2/n2cpu_nii51010.pdf).
