12748 Discussions
simple socket server example on cyclone II dev kit
I want to use the simple socket server example with the cyclone II dev kit. I compiled it and then I run it. In the file simple_socket_server.h I defined the IP-adress like this:
#define IPADDR0 192# define IPADDR1 168# define IPADDR2 1# define IPADDR3 234 #define GWADDR0 192 # define GWADDR1 168 # define GWADDR2 1 # define GWADDR3 1 #define MSKADDR0 255# define MSKADDR1 255# define MSKADDR2 255# define MSKADDR3 0
The IP-Adress of my PC is 192.168.1.1 with the same subnet adress. Then I connected the Board directly via Ethernet to my PC.
In the console I can read the following:
Your Ethernet MAC address is 00:07:ed:0f:b4:14 prepped 1 interface, initializing... Created "Inet main" task (Prio: 2) Created "clock tick" task (Prio: 3) smsc91c111 Auto-negotiation: 100 Mbps, Full Duplex SMSC ethernet Rev: 0x3392, ram: 8192 IP address of et1 : 0.1.1.234 DHCP timed out, going back to default IP address(es) Simple Socket Server starting up Simple Socket Server listening on port 30 Created "simple socket server" task (Prio: 4)
But now I can't reach the board by a ping (icmp-request) and of course I can't connect via TCP to the board. I wonder why it says that the IP-adress is 0.1.1.234
1. This is no valid ip-adress, because it includes a zero...
2. It's not the same as I defined it in simple_socket_server.h
Who can help? :)
Stefan
P.S.: When I press "run" it takes ~5 minutes until it's really running...
Idon't know what to say about your post but I can give you an example of I have done for Stratix 3 development board.
IP: 137.57.123.58
GW: 137.57.123.200
MASK: 255.255.255.0
in my pc : IP: 137.57.123.55
MASK: 255.255.255.0
GW: 137.57.123.200
under cmd window : ping 137.57.123.58 -t
I hope this will be helpfull.
Jeremy.
Press enter to look up in Wiktionary or ctrl+enter to look up in Wikipedia
hi jjeerreemmyy,
did you connect your board directly to the pc? did you use a special cable?
and what was the console output when you launch the application?
I connected the board with the "usb blaster cable" .
I used the example that uses triple speed ethernet. This example is included with the design kit but it's targetting cyclone ii family. However, you can use it I think.
So, to answer to your second question (if I well understood):
The output of the console was : " Reply from 137.57.123.58: bytes=32 time<1ms TTL=64 " .This show that the connection is established.
Jeremy.
--- Quote Start ---
--- Quote End ---
And no ethernet cable?
Yes sorry :)
And what was the console output in NIOS II IDE when you launched the application?
________
NIOS II IDE is very strange...
Sometimes there is a build error and sometimes not. Also if I don't change the code.
Anyhow, it's still not working and I don't know why...
Which version of Quartus are you using? In 8.0 there was a bug in the IP4_ADDR macro in network_utilites.c. It should have an extra pair of brackets, and should look like this:
#define IP4_ADDR(ipaddr, a,b,c,d) ipaddr = htonl((((alt_u32)(a & 0xff) << 24) | ((alt_u32)(b & 0xff) << 16) | ((alt_u32)(c & 0xff) << 8) | (alt_u32)(d & 0xff)))
Hey Daixiwen,
Yes, you were right. I added the brackets and then it worked. :)
>> http://www.altera.com/support/kdb/solutions/rd06062008_934.html
Hi, I am trying to use simple socket server example on cyclone II dev kit.
It seems to work BUT :
when i send over 41 characters through ethernet (crossed câble) , dev kit goes to malfunction.
I receive random characters and communication hangs.
It is like there is too many characters. Too much work to do for Nios II + IP stack + microC/OS II.
Have you faced to this problem ?
Is there an example of Simple Socket server PLus (that enables FTP, TFTP, ...) for Cyclone II dev kit ?
EDIT :
--- Quote Start ---
[SSS]: Attempted to post to a full message queue.
--- Quote End ---
