I want to use the simple socket server example with the cyclone II dev kit. I compiled it and then I run it. In the file simple_socket_server.h I defined the IP-adress like this:
#define IPADDR0 192# define IPADDR1 168# define IPADDR2 1# define IPADDR3 234
#define GWADDR0 192 # define GWADDR1 168 # define GWADDR2 1 # define GWADDR3 1
#define MSKADDR0 255# define MSKADDR1 255# define MSKADDR2 255# define MSKADDR3 0
The IP-Adress of my PC is 192.168.1.1 with the same subnet adress. Then I connected the Board directly via Ethernet to my PC. In the console I can read the following:
Your Ethernet MAC address is 00:07:ed:0f:b4:14
prepped 1 interface, initializing...
Created "Inet main" task (Prio: 2)
Created "clock tick" task (Prio: 3)
smsc91c111 Auto-negotiation: 100 Mbps, Full Duplex
SMSC ethernet Rev: 0x3392, ram: 8192
IP address of et1 : 0.1.1.234
DHCP timed out, going back to default IP address(es)
Simple Socket Server starting up
Simple Socket Server listening on port 30
Created "simple socket server" task (Prio: 4)
But now I can't reach the board by a ping (icmp-request) and of course I can't connect via TCP to the board. I wonder why it says that the IP-adress is 0.1.1.234: 1. This is no valid ip-adress, because it includes a zero... 2. It's not the same as I defined it in simple_socket_server.h Who can help? :) Regards, Stefan P.S.: When I press "run" it takes ~5 minutes until it's really running...
Idon't know what to say about your post but I can give you an example of I have done for Stratix 3 development board. In the file simple_socket_server.h I defined the IP-adress like this: IP: 137.57.123.58 GW: 137.57.123.200 MASK: 255.255.255.0 in my pc : IP: 137.57.123.55 MASK: 255.255.255.0 GW: 137.57.123.200 under cmd window : ping 137.57.123.58 -t I hope this will be helpfull. Best regards, Jeremy. Press enter to look up in Wiktionary or ctrl+enter to look up in Wikipedia- Mark as New
hi jjeerreemmyy,
did you connect your board directly to the pc? did you use a special cable? and what was the console output when you launch the application?- Mark as New
I connected the board with the "usb blaster cable" .
I used the example that uses triple speed ethernet. This example is included with the design kit but it's targetting cyclone ii family. However, you can use it I think. So, to answer to your second question (if I well understood): The output of the console was : " Reply from 137.57.123.58: bytes=32 time<1ms TTL=64 " .This show that the connection is established. Regards, Jeremy. Press enter to look up in Wiktionary or ctrl+enter to look up in Wikipedia- Mark as New
--- Quote Start --- I connected the board with the "usb blaster cable" . --- Quote End --- And no ethernet cable?
Yes sorry :)
And what was the console output in NIOS II IDE when you launched the application?
________ NIOS II IDE is very strange... Sometimes there is a build error and sometimes not. Also if I don't change the code.- Mark as New
Anyhow, it's still not working and I don't know why...
Which version of Quartus are you using? In 8.0 there was a bug in the IP4_ADDR macro in network_utilites.c. It should have an extra pair of brackets, and should look like this:
#define IP4_ADDR(ipaddr, a,b,c,d) ipaddr =
htonl((((alt_u32)(a & 0xff) << 24) | ((alt_u32)(b & 0xff) << 16) |
((alt_u32)(c & 0xff) << 8) | (alt_u32)(d & 0xff)))
Hey Daixiwen,
Yes, you were right. I added the brackets and then it worked. :) >> http://www.altera.com/support/kdb/solutions/rd06062008_934.html- Mark as New
Hi, I am trying to use simple socket server example on cyclone II dev kit.
It seems to work BUT : when i send over 41 characters through ethernet (crossed câble) , dev kit goes to malfunction. I receive random characters and communication hangs. It is like there is too many characters. Too much work to do for Nios II + IP stack + microC/OS II. Have you faced to this problem ? Is there an example of Simple Socket server PLus (that enables FTP, TFTP, ...) for Cyclone II dev kit ? EDIT : --- Quote Start --- [SSS]: Attempted to post to a full message queue. --- Quote End ---
