12748 Discussions
some questions about registers in nios2
i have some questions about registers in nios2
1: the GP(r26)' function like PC as in X86 architecture ?
2: (r15-r8) is named Caller-Saved registers ,their function ?
3:(r16_r23),their function ?
4: when call a function, the rule of saving registers is what? between r2 to
r25 ,which should be saved ?
5: when an interrupt happen or call function , the differences between the saving registers and restore register action.
Hi wkongwkong,
Please see the "Nios II Processor Reference Handbook":
http://www.altera.com/literature/lit-nio2.jsp (http://www.altera.com/literature/lit-nio2.jsp
--Scott
--- Quote Start ---
1: the gp(r26)' function like  pc as in x86 architecture ?
2: (r15-r8) is named  caller-saved  registers ,their function ?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16354)
--- quote end ---
--- Quote End ---
1. I&#39;m rusty on my x86 so I&#39;m not sure of the answer to this.
2. Caller saved registers have to be saved by the calling function. So if you&#39;re writing in assembler you don&#39;t have to bother saving them.
3. They&#39;re just registers that you can do with what you will
4. When calling a function if doing it from assembler you should save the caller saved registers. If you do the call from C the compiler looks after this for you.
5. If you want to know which registers are saved for an IRQ look in the file alt_exception_entry.S in the nios2 component
