spi write/read time out
to what occurrence of these lines can be connected at loading a nucleus?
whether there was a similar situation at someone else?
Linux version 2.6.11-uc0 (SFx@lab1p4) (gcc version 3.4.1 (Altera Nios II 5.0 b73))# 5 Thu Aug 25 14:07:58 2005
uClinux/Nios II
Altera Nios II support © 2004 Microtronix Datacom Ltd.
Built 1 zonelists
Kernel command line: root=/dev/mtdblock0 ro
PID hash table entries: 128 (order: 7, 2048 bytes)
spi_write time out
spi_read write address time out
Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
Memory available: 14740k/16384k RAM, 0k/0k ROM (1196k kernel code, 255k data)
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
Linux NoNET1.0 for Linux 2.6
SPI: Nios SPI bus device version 0.1
NIOS serial driver version 0.0
ttyS0 (irq = 4) is a builtin NIOS UART
Serial: JTAG UART driver $Revision: 1.4 $
ttyJ0 at MMIO 0x80920820 (irq = 1) is a jtag_uart
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered
RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize
Microtronix map: Found 1 x16 devices at 0x0 in 16-bit bank
Amd/Fujitsu Extended Query Table at 0x0040
Microtronix map: CFI does not contain boot bank location. Assuming top.
number of CFI chips: 1
cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
cmdlinepart partition parsing not available
Searching for RedBoot partition table in Microtronix map at offset 0x7f0000
No RedBoot partition table detected in Microtronix map
Using Microtronix development partition definition
Creating 4 MTD partitions on "Microtronix map":
0x00200000-0x00700000 : "romfs"
0x00000000-0x00200000 : "loader/kernel"
0x00500000-0x00580000 : "usersapace"
0x00580000-0x00600000 : "other"
blkmtd: version $Revision: 1.5 $
blkmtd: error: missing `device' name
block2mtd: version $Revision: 1.1.1.1 $
VFS: Mounted root (romfs filesystem) readonly.
Freeing unused kernel memory: 52k freed (0x114a000 - 0x1156000)
expand: from=/ramfs.img to=/dev/ram0
expand: from=/ramfs.img to=/dev/ram1
SIOCSIFADDR=-1: 9
SIOCGIFFLAGS = -1: Bad file descriptor (9)
SIOCADDRT=-1: 9
/bin/inetd: not found
/bin/boa: not found
/etc/issue www.microtronix.com June 2005
Welcome to Linux on the Nios II
Nios2 login:
if such lines appear that spi interface does not work in uclinux.
thanks for the help!
Please check the hardware first,
is the SPI device fall to work or the lines of SPI not connected properly.
