stand-alone lwip ARP problem
Dear all !
I have downloaded stand-alone lwip from our forum "Test IP" .My design is to build a simple udp-client that sending data to PC with stand-alone lwip .But this version seems too old (version 0.7.1,developped on 2005 ,now the lastest version is 1.3.0)I guess MAYBE there is a bug in ARP modle ,here is the problem i hit:
If i run my application, it does not send any UDP packets ( see that in Ethereal ).
However ,after runing anther application udp_echo (data send and return ) ,stop it and run my application ,my app runs very well .I 'm very confused !
So i guess MAYBE there is a bug in our stand-alone lwip .Here is my reason.
when i run the UDP_ECHO app, PC send a udp packet to board ,so our board konw the IP address and MAC addess of PC ,and update it to ARP cache . Then run my app ,the app konws the destination host ' IP address and MAC addess (PC),so it works well. If i run my app only ,it does not konw the PC 's MAC addess , therefore it work fail.Though PC send gratuitous arps ,but the lwip can't update it to the ARP cache .
Am i right ? And how to resolve it ?
Is there someone work similar with me ? or could send a simple udp-client example (stand-alone lwip version) to me !
Thank you ! My MSN and my email is the_gadfly@163.com
----------my app-------------
P4_ADDR(&udpDestIpAddr, 10, 1 ,1, 52);
p = pbuf_alloc(PBUF_TRANSPORT,sizeof(Test),PBUF_RAM);
memcpy(p->payload, Test, sizeof(Test));
pcb = udp_new();
udp_bind(pcb, IP_ADDR_ANY, 60000);
udp_connect(pcb, &udpDestIpAddr, 60000);
for(i=0;i<1000;i++)
udp_send(pcb,p);
pbuf_free(p);
udp_remove(pcb);
--------udp_echo app------------
void udp_echo_recv(void *arg, struct udp_pcb *pcb, struct pbuf *p, struct ip_addr *addr, u16_t port)
{ struct ip_addr ipaddr;
IP4_ADDR(&ipaddr,10,1,1,52);
if (p != NULL)
udp_connect(pcb,&ipaddr,60000);
udp_send(pcb, p);
pbuf_free(p);
void udp_echo_init(void)
struct udp_pcb * pcb;
pcb = udp_new();
udp_bind(pcb, IP_ADDR_ANY, 60000) ;
udp_recv(pcb, udp_echo_recv, NULL);
Best regards
the_gadfly
Apara
I too want to implement the lwip with DE2-115 FPGA , But I am facing difficulty in  spoc builder component connections.As I am new Altera I tried  with basic Ethernet design based on below link.
https://www.intel.com/content/www/us/en/programmable/support/support-resources/design-examples/intellectual-property/embedded/nios-ii/exm-net-std-de.html?elq_cid=5141484_ts1621585352433&erpm_id=2899670_ts1621585352433
When I adding these component and additional peripheral as suggest in message , I unable connect these.
I am confuse what should  the component, its value and how to connect with others.Please guide little
