starter,want help!
hello,every body.
sorry for my poor english,my first language is not englsh.i began to learn niosII about two weeks ago,and i want to design a fpga which contains a soft cpu core to replace MCU(MCS-51,e.g.8031).The c code of the 8031 are partly as follows:# include <reg51.h># include <intrins.h># include <absacc.h>
long i,j;
sbit p10=P1^0;
sbit p11=P1^1;
sbit p12=P1^2;
sbit p14=P1^4;
sbit p15=P1^5;
sbit p13=P1^3;
main()
InitializeA();
TMOD=0x20;
TL1=0xfd;TH1=0xfd;
PCON=0x00;
TR1=1;
p11=0; p11=1
xx=0;
while(1)
p11=1;
//delay(20);
p11=0;
//delay(20);
p11=1;
p12=0;
p13=1;
p10=0;
p10=1;
i=0;
p15=1;
xx=p15;
while (xx==0)
p15=1;
xx=p15;
p15=1;
xx=p15;
if(xx==1)
p11=0;
p11=1;
p12=1;
for(i=0;i<286;i++)
{//for1
for(j=0;j<360;j++)//720
{ //for2
P0=0xff;
re_am=P0;
if(j<359) //718 359
SBUF=re_am;
while(TI==0)
TI=0; //delay(5);
P2=0xff;
re_am=P2;
if(j<359)//359
SBUF=re_am;
while(TI==0)
TI=0; //delay(5);
p13=0;p13=1;
} //for2
} //for1
}//if_end
}//first while_end
i want to write this code into niosII,and use the cpu soft core to achieve the fuctions play by the MCU.
as show above,MCU uses p10...p17 as control signals,how can i achieve this in nios?can i use PI/Os to replay p10...p17 to play control fuctions?if it does,how can i link the p10...p17 to the PI/Os in c code?
and SBUF in MCU is a serial port,can i use UART to replace it?and the examples altera provides always use UART to transfer charicters,then how can i use it to transfer control signals,as 0,1?
i think the function i want to achieve is not difficult,but i am a poor starter,and i have been confused with it for a long time .can you help me with it ,kind persons?
I think you should look at the documentation, which can be found in the altera\kits\nios2\documents directory, probably starting with n2cpu_nii5v1.pdf and n2sw_nii5v2.pdf.
After that if you launch the Nios II IDE, you&#39;ll find lots of helpful tutorials.
