stdm++.cxx Error
Hi~
I have error when I compile my image using uClinux with MMU
Once my program have printf function, I will got follow error
stdm++.cxx:1:18: error: stdm++: No such file or directory
stdm++.cxx:4: error: 'MATT' has not been declared
stdm++.cxx:4: error: expected constructor, destructor, or type conversion before '(' token
stdm++.cxx:21: error: 'MATT' has not been declared
stdm++.cxx:21: error: expected constructor, destructor, or type conversion before '::' token
stdm++.cxx:34: error: 'MATT' has not been declared
stdm++.cxx:34: error: 'int operator<<(char*)' must have an argument of class or enumerated type
stdm++.cxx:34: error: 'int operator<<(char*)' must take exactly two arguments
stdm++.cxx: In function 'int operator<<(char*)':
stdm++.cxx:36: error: invalid use of 'this' in non-member function
stdm++.cxx:36: error: 'fprintf' was not declared in this scope
stdm++.cxx: At global scope:
stdm++.cxx:41: error: 'MATT' has not been declared
stdm++.cxx:41: error: expected constructor, destructor, or type conversion before 'MATT'
I saw a solution from (http://www.mail-archive.com/uclinux-dev@uclinux.org/msg00170.html
//-------------------------------From Website----------------------------------------------//
There are some pieces missing from the test c++ apps. Find attached a patch. Dave/Gerg would you mind applying this to the tree.
The problem with iperf is that you are not linking against pthread.
I haven't tried building iperf, but I do notice that your link line does not include pthreads and you will need to add this. Adding $ (SLIBPTHREAD) to your link line should fix the problem.
(What is link line? My Makefile??)
You will need to build STLport statically at the moment using the gcc 3.4.4 toolchain. To do this customize your vendor/user settings, go in to 'Library Configuration' and ensure that 'Build STL port as shared' is set to 'n'.
The problem occurs because stl port is attempting to link against the shared version of libgcc (libgcc_s.so). Building STLport statically means that it will attempt to link against the static version - libgcc.a
However I still don't understand how to do it.
Does anyone give me more detial instruction?
Another problem is actual I unselect the c++ test program the error still show?
Does anyone know why causing this?
I got to this post searching for the error message bellow that I got when I was trying to build my uclinux for the first time after updating it(to 3.7)
"stdm++.cxx:1:18: error: stdm++: No such file or directory"
In my case, I was just missing the uuid-dev lib for Ubuntu
apt-get install uuid-dev
cheers
