step-14: Buildroot Guide
Hi Hippo,
After running uclinux successfully on startix pro (Nios II).
I have to enable some applications:
1. telnel
2. tftp
3. SSH login
According to step 14, i will able to enable those apps.
After selecting those options through menuconfig.
It got failed at "make subdirs".
Kindly, Explain step 14 little-bit more. so i can configure any apps.
thanks & regard,
Goutam
--- Quote Start ---
originally posted by goutam_kumar@May 9 2006, 07:13 PM
hi hippo,
after running uclinux successfully on startix pro (nios ii).
i have to enable some applications:
        1.  telnel
        2.  tftp
        3.  ssh login
according to step 14, i will able to enable those apps.
after selecting those options through menuconfig.
it got failed at "make  subdirs".
kindly, explain step 14 little-bit more. so i can configure any apps.
thanks & regard,
goutam
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15218)
--- quote end ---
--- Quote End ---
Please enable only one apps at a time, to see which failed to make.
Check the compile message. Lack of include file ?
You can also try the same patches against stable release of uClinux-dist, which may have better result. I will change the buildroot guide and build script to use the stable one instead of test release.
Hi Hippo,
Thanks for hint.
I was doing same what you have instructed.
while doing "make romfs". it is going failed.
The required ".config" file for ~/rootfs/etc for an apps is not so clear.
Acknowledge me, when you will modify the buildroot guide steps.
I compiled for busybox using step 14. it got hang with vfork in
"~/uClinux-dist-test/user/busybox/networking/inetd.c: line766"
with following error
/home/goutam/uClinux-dist-test/user/busybox/networking/inetd.c:766: error: too few arguments to function `vfork_daemon_rexec&#39;
make[2]: *** [/home/goutam/uClinux-dist-test/user/busybox/networking/inetd.o] Error 1
make[2]: Leaving directory `/home/goutam/uClinux-dist-test/user/busybox&#39;
make[1]: *** [all] Error 2
make[1]: Leaving directory `/home/goutam/uClinux-dist-test/user&#39;
make: *** [subdirs] Error 1
thanks & regard,
Goutam
