struct
The following code works fine:
# define RAMSHADOWBASE 0x01010000# define TESTVARIABLE (*(unsigned int*)RAMSHADOWBASE)
Now I want to add a struct on the same way. Thus I want to place a structure on a predefined adress in RAM memory.
Struct looks like:
struct Defs
unsigned int Nr;
unsigned int Place;
} lacingHole[40];
Somebody a solution for this?
Nobody a solution????
--- Quote Start ---
originally posted by innotronics@Jan 9 2007, 10:40 AM
the following code works fine:
# define ramshadowbase  0x01010000# define testvariable        (*(unsigned int*)ramshadowbase)
now i want to add a struct on the same way. thus i want to place a structure on a predefined adress in ram memory.
struct looks like:
struct defs
  unsigned int nr;
  unsigned int place;
} lacinghole[40];
somebody a solution for this?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=20433)
--- quote end ---
--- Quote End ---
Hi innotronics,
There are two common ways of accomplishing what (I believe) you want:
1, access the structure via a pointer:#define DEFSBASE  0x01010000 struct Defs *pDefs = (struct Defs *) DEFSBASE; ... pDefs->Nr = <<whatever>>
or ...
2. put the structure in a named section ...struct Defs  myDefs __attribute__ ((section (",defs"))); myDefs.Nr = <<whatever>>
... then locate the section where you want in your linker command file.__defs_start = .;     .defs :     {   *(.defs)     }
--Scott
