struct
struct test
int number;
char name[20];
test t;
in the nios ide the compiler says: test undeclared, why?
--- Quote Start ---
originally posted by asegers@Jul 19 2006, 01:18 PM
struct test
    int number;
    char name[20];
  test  t;
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=17003)
--- quote end ---
--- Quote End ---
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
try
typedef struct test
int number;
char name[20];
test t;
--- Quote Start ---
originally posted by slava+jul 19 2006, 11:46 am--><div class='quotetop'>quote (slava @ jul 19 2006, 11:46 am)</div>
--- quote start ---
<!--quotebegin-asegers@Jul 19 2006, 01:18 PM
struct test
    int number;
    char name[20];
  test  t;
--- quote end ---
--- Quote End ---
try
typedef struct test
int number;
char name[20];
thanks, but still the same err.
test t;
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=17006)</div>
[/b]
--- Quote End ---
Hi asegers,
I think you are right in declaration point of..
Just try out this one too::::
typedef struct test
int number;
char name[20];
}t;
And plz check one thing..the header file( In which you define this structure declaration) is must be include in your source file(*.c). so your source file get the declaration of this structure and your compiler will compile the code without error..
slsnios
TO_BE_DONE
or type
&#39;struct test t&#39;
--- Quote Start ---
originally posted by asegers@Jul 19 2006, 06:18 AM
struct test
    int number;
    char name[20];
  test  t;
--- quote end ---
--- Quote End ---
