12748 Discussions
CFI and different Command Definition Tables
I am having problems using Quartus Flash Programmer to erase/program CFI flash made by Atmel.
I have a single 64 megabit chip at49bv6416 on my board hooked up to Nios II using Avalon bus and it uses 16-bit data bus.
I know it has a different Command Definition Table than a similar 64 megabit, also CFI compatible chip made by AMD (am29lv640mh).
For example, "Program Word" command for Atmel chip is following sequence:
555/aa
aaa/55
555/a0
for AMD chip the sequence is:
555/aa
2aa/55
555/a0
how the quartus flash programmer "knows" what sequence to use for my chip ?
Command values does not seem to be coded in CFI table...
Do I configure it in some quartus/project file to match my flash chip?
Have you looked at the flash programmer user's guide (http://www.altera.com/literature/ug/ug_nios2_flash_programmer.pdf).
You may be able to define an override to get your CFI "compliant" flash to function.
- slacker
Yes, I have looked in this file and I learned something new: I can use Flash Programmer in command-line mode to display some more debug messages.
Here is my output from the program for my board:
Using cable "USB-Blaster ", device 1, instance 0x01 Resetting and pausing target processor: OK Reading System ID at address 0x00900BC8: verified Found CFI table in 16 bit mode Raw CFI query table read from device:   0: 1F 00 D6 00 FF FF FF FF  FF FF FF FF FF FF FF FF  ................  10: FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  ................  20: 51 00 52 00 59 00 02 00  00 00 41 00 00 00 00 00  Q.R.Y.....A.....  30: 00 00 00 00 00 00 27 00  36 00 09 00 0A 00 04 00  ......&#39;.6.......  40: 00 00 09 00 10 00 04 00  00 00 03 00 03 00 17 00  ................ CFI query table read from device:  10: 51 52 59 02 00 41 00 00  00 00 00 27 36 09 0A 04  QRY..A.....&#39;6...  20: 00 09 10 04 00 03 03 17  01 00 00 00 02 7E 00 00  .............~..  30: 01 07 00 20 00 FF FF FF  FF FF FF FF FF FF FF FF  ... ............  40: FF                                                . CFI extended table read from device:   0: 50 52 49 31 30 AF 01 00  01 80 03 03 FF FF FF FF  PRI10...........  10: FF FF FF FF FF FF FF FF  FF FF FF FF FF FF FF FF  ................ Read autoselect code 001F-00D6 (in 16 bit mode) No CFI override data for Device size is 8MByte Erase regions are:  offset        0: 127 x 64K  offset   7F0000:   8 x 8K Device supports AMD style programming algorithm Multi-byte programming not supported Sector erase timeout is 4s Word program timeout is 256us              : Checksumming existing contents 00200000      : Checksum failed - needs erase then program 00210000      : Checksum failed - needs erase then program 00220000      : Checksum failed - needs erase then program 00230000      : Checksum failed - needs erase then program 00200000      : Reading existing contents 00210000      : Reading existing contents 00220000      : Reading existing contents 00230000      : Reading existing contents Checksummed/read 14kB in 0.4s 00200000 ( 0%): Erasing 00210000 (25%): Erasing 00220000 (50%): Erasing 00230000 (75%): Erasing Erased 256kB in 0.0s 00200000 ( 0%): Programming Program sequence:  Write address 0x00000000 <= 0xF0  Write address 0x0000AAAA <= 0xAA  Write address 0x00005554 <= 0x55  Write address 0x0000AAAA <= 0xA0  Write address 0x00200010 <= 0xD76A  Read  address 0x00200010 => 0xE4 Program failed at offset 200010 Leaving target processor paused
Doing this, I can see the wrong program sequence is used, but I am not sure how to change it to the correctl one. Yes, I can override CFI table using --override=<filename> parameters, but how do I find numbers for CFI table to override?
Any ideas ?
Get out your datasheet and compare the read CFI table values with what should be there. Use the override table to "replace" these bad values for (in your case) FLASH-001F-00D6.
You might be able to find some examples of doing this, on this forum, or, if not, definitely on Altera&#39;s website.
Best of luck and good job using the --debug option. I&#39;m sorry I didn&#39;t recommend it to you, in the first place.
Cheers,
- slacker
