tcp socket program puzzle
Hello everyone:
I am learning and testing TCP socket program. In my application, I want to send and receive a great deal of data at one time. So the quantity of data exceed the size of array I can define in the program. I have used different methods to resolve this problem, but the result is not good.
Can any one give me some suggestions? Thanks a lot!
if i understand you right, you cannot define a buffer, which is big enough; for example:
char buffer;
so if i'm right you should try to use the malloc function ; in this case (*EDIT* for buffers greater than 1MB) you need to enable a kernel option to do so (for big portions of memory):
Processor type and features --> Allow allocating large blocks....
Greets
helmchen
--- Quote Start ---
char buffer;
so if i'm right you should try to use the malloc function ; in this case (*edit* for buffers greater  than 1mb) you need  to enable a kernel option to do so (for big portions of memory):
processor type and features --> allow allocating large blocks....
greets
helmchen
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=20794)</div>
--- Quote End ---
Thank you helmchen, you have understand me right.
Can I ask two more questions?
1, I have seen the option in the configure interface, but I wonder the kernel take use of what for the large blocks?
2, Can I just use the limited buffer to carry out large data transmission? For example, send several times?(I have tested, but still can&#39;t find good methods..)
Thanks again http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
1, I have seen the option in the configure interface, but I wonder the kernel take use of what for the large blocks?[/b]
--- Quote End ---
well i&#39;m not a kernel crack. Maybe you take a look at
http://www.linuxdevices.com/articles/at7777470166.html (http://www.linuxdevices.com/articles/at7777470166.html) and in the kernel docs.
Maybe someone else can explain it in short.
--- Quote Start ---
Can I just use the limited buffer to carry out large data transmission? For example, send several times?(I have tested, but still can&#39;t find good methods..[/b]
--- Quote End ---
you can reuse your buffers...
--- Quote Start ---
--- Quote End ---
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=20816)</div>
--- Quote End ---
Thanks again, kind helmchen.
I have tried to reuse the buffers, for example, server send two times and client receive two times. But the result is not right..
I only found a method that is(TCP):
After send and receive once, client close the connection. And then establish another connetion and perform another transmition..
So in this way, If I need reuse my buffer ten times to finish the transmition, I have to establish and close the connection ten times..
Below is a segment of the client program to help you understand me.
//The first connection, receive 1500 bytes
sockfd = socket(AF_INET,SOCK_STREAM,0);
bzero((struct sockaddr*)&serveraddr,sizeof(serveraddr));
serveraddr.sin_family=AF_INET;
serveraddr.sin_port=htons(5000);
inet_pton(AF_INET,argv[1],&(serveraddr.sin_addr));
if((connect(sockfd,((struct sockaddr*)&serveraddr),sizeof(serveraddr)))<0)
printf("connect error!!\n");
recvbyte=recv(sockfd,recvbuff,1500,0);
printf("recvbyte1=%d\n",recvbyte);
close(sockfd);
//The second connection,receive 1500 bytes.
printf("recvbyte2=%d\n",recvbyte);
close(sockfd);
I think it&#39;s not a good way, so I am searching the good ways to reuse buffer. Do you have any good suggestions?
maybe you can also post the code for sending?
the receiving code looks good for me.
