tinylogin enable issue
Hello Hippo,
Using buildroot guide step-14.
I got the image for tftpd and tinylogin.
I kept those images from romfs to rootfs dir respectively.
1.) I wrote "ttys0:vt100:/bin/agetty 115200 ttys0" in rootfs/etc/inittab for tinylogin.
After kernel boot process the login process didn't come.
what should I do now.
2.) To compile ssl, ssh and sshd as statically the changes require in Makefile.
Kindly explain it?
3.) Using inetd patch reference, I made change in tftpd/Makefile. It create the
Image successfully.
I tried to write the patch for that. but I am unable.
can I send the modified telnetd/Makefile to you for mx140apps.diff updation.
Kindly acknowledge me.
thanks & regard,
Goutam
--- Quote Start ---
originally posted by goutam_kumar@May 15 2006, 06:58 PM
hello hippo,
using buildroot guide step-14.
i got the image for tftpd and tinylogin.
i kept those images from romfs to rootfs dir respectively.
1.) i wrote "ttyS0:vt100:/bin/agetty 115200 ttyS0[/b]" in rootfs/etc/inittab for tinylogin.
Kindly explain it?
Image successfully.
thanks & regard,
Goutam
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15378)
--- Quote End ---
[/b]
--- Quote End ---
1. check if you have the right tty devices, jtag uart or serial uart have different device number.
2. you should compile openssl lib in buildroot, but tftpd, ssh and sshd in uClinux-dist.
I shall include the patches of openssl and zlib to buildroot.diff, if I can find some spare time.
3. thank you, please post as attachment in the buildroot guide thread.
I am thinking of drop the mx140apps and use only uClinux-dist for apps. How do you think?
--- Quote End ---
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15393)</div>
--- Quote End ---
Hello Hippo,
First of-all thanks for apreciating my suggestion.
I think it will be a good option. because we want to enable apps. but for different apps have work with both dir apps/ and uClinux-dist/.
Kindly add the patch to mx140apps.diff as patch for telnetd
The below is telnetd-Makefile modified version (modified by Goutam)
***# # configurable options# - set DEBUG = 1 to turn on debugging support#
DEBUG = 0
PROJ_NAME = telnetd
INSTALL_DIR = ~/rootfs
PROGS := $(PROJ_NAME)
CFLAGS += -O2
CROSS := nios2-linux-uclibc-
CC := $(CROSS)gcc
# # You should not need to modify anything beyond this point#
FLTFLAGS := -s 8192
CFLAGS += -DPARANOID_TTYS
-DTERMCAP
-DUSE_TERMIO
-DKLUDGELINEMODE
-D_GNU_SOURCE
OBJS = global.o logwtmp.o state.o telnetd.o termstat.o
authenc.o logout.o slc.o sys_term.o utility.o
all: $(PROGS)
$(PROJ_NAME): $(OBJS)
$(CC) -elf2flt="$(FLTFLAGS)" -o $@ $^
.PHONY: clean
clean:
-rm -f *.[oad] *.gdb $(PROJ_NAME)
.PHONY: install
install: all
ifeq "$(INSTALL_DIR)" ""
$(error No installation directory specified)
endif
mkdir -p $(INSTALL_DIR)/bin
install -v $(PROGS) $(INSTALL_DIR)/bin
