u-boot without flash device
Is there any way to skip the flash check on the beginning of u-boot ??
U-Boot 2009.03-00006-g3387a3e-dirty (Dec 17 2010 - 15:42:36)
CPU : Nios-II
SYSID : <unknown>
BOARD : My Board# # Unknown FLASH on Bank 1 - Size = 0x00000000 = 0 MB
*** ERROR: unimplemented instruction @ f2fd00a0# ## ERROR# ## Please reset board# ##
Since I do not have any CFI-Flash, it failing.
CFG_NO_FLASH option did not work.
CONFIG_ENV_IS_NOWHERE option did not work.
Solved.
define config_sys_no_flash
do not define config_flash_cfi_driver
do not define config_cmd_flash (undefine it if necessary
do not define config_cmd_imls (undefine it if necessary)
You may still see error in compilation.
Go to u-boot/lib_nios2/board.c
around line 155, comment out the line
//bd->bi_flashsize = flash_init();
At least, this will give you a command prompt of the u-boot.
Or simply the board.c file should use# ifdef to process this line.
1 more thing. If you are using the config_cmd_default, then...
In side of u-boot/include/config_cmd_default.h
around line 25, comment out# define CONFIG_CMD_FLASH
It seems like this issue was cause by using older version of u-boot.
I was using 20090730 version.
In the new version, 20100621, this issue has been fixed.
