12748 Discussions
Device Archive File (*.qda) problem during 10.1 installation in Linux
Hi All,
I am getting the following error while installing 10.1 on Linux. I used the command line method i.e. using setup command and some options to install quartus alone.
Quartus II tool, as such, has got installed properly. After that, the device related installations started and it failed with the following error.
Please help.
prompt> quartus_sh --qinstall -qda stratixiv.qda
Info: *******************************************************************
Info: Running Quartus II Shell
Info: Version 10.1 Build 153 11/29/2010 SJ Full Version
Info: Copyright (C) 1991-2010 Altera Corporation. All rights reserved.
Info: Your use of Altera Corporation's design tools, logic functions
Info: and other software and tools, and its AMPP partner logic
Info: functions, and any output files from any of the foregoing
Info: (including device programming or simulation files), and any
Info: associated documentation or information are expressly subject
Info: to the terms and conditions of the Altera Program License
Info: Subscription Agreement, Altera MegaCore Function License
Info: Agreement, or other applicable license agreement, including,
Info: without limitation, that your use is for the sole purpose of
Info: programming logic devices manufactured by Altera and sold by
Info: Altera or its authorized distributors. Please refer to the
Info: applicable agreement for further details.
Info: Processing started: Fri Dec 17 17:34:19 2010
Info: Command: quartus_sh --qinstall -qda stratixiv.qda
Info: Quartus(args): -qda stratixiv.qda
Info: ----------------------------------------------------------
Info: qinstall.tcl version# 1
Info: Device install directory: /tools/hw/quartus/10.1/quartus/common/devinfo
Info: File(s) to install:
Info: stratixiv.qda
Info: Installation may take a while
Error: ERROR: Failed to restore "stratixiv.qda" because some files could not be processed. Refer to "stratixiv.qdalog".
Error: Failed to install stratixiv.qda -- make sure you specified a valid Quartus II Device Archive (.qda) file
Error: Evaluation of Tcl script /tools/hw/quartus/10.1/quartus/common/tcl/apps/qpm/qinstall.tcl unsuccessful
Error: Quartus II Shell was unsuccessful. 3 errors, 0 warnings
Error: Peak virtual memory: 83 megabytes
Error: Processing ended: Fri Dec 17 17:36:04 2010
Error: Elapsed time: 00:01:45
Error: Total CPU time (on all processors): 00:00:01
Wrong Forum. Please post this at a Quartus forum to get decent answers.
-Michael
