Hi All,
I am getting the following error while installing 10.1 on Linux. I used the command line method i.e. using setup command and some options to install quartus alone. Quartus II tool, as such, has got installed properly. After that, the device related installations started and it failed with the following error. Please help. /////////////////////////////////////////////////////////////////////////// prompt> quartus_sh --qinstall -qda stratixiv.qda Info: ******************************************************************* Info: Running Quartus II Shell Info: Version 10.1 Build 153 11/29/2010 SJ Full Version Info: Copyright (C) 1991-2010 Altera Corporation. All rights reserved. Info: Your use of Altera Corporation's design tools, logic functions Info: and other software and tools, and its AMPP partner logic Info: functions, and any output files from any of the foregoing Info: (including device programming or simulation files), and any Info: associated documentation or information are expressly subject Info: to the terms and conditions of the Altera Program License Info: Subscription Agreement, Altera MegaCore Function License Info: Agreement, or other applicable license agreement, including, Info: without limitation, that your use is for the sole purpose of Info: programming logic devices manufactured by Altera and sold by Info: Altera or its authorized distributors. Please refer to the Info: applicable agreement for further details. Info: Processing started: Fri Dec 17 17:34:19 2010 Info: Command: quartus_sh --qinstall -qda stratixiv.qda Info: Quartus(args): -qda stratixiv.qda Info: ---------------------------------------------------------- Info: ---------------------------------------------------------- Info: qinstall.tcl version# 1 Info: ---------------------------------------------------------- Info: ---------------------------------------------------------- Info: Device install directory: /tools/hw/quartus/10.1/quartus/common/devinfo Info: File(s) to install: Info: stratixiv.qda Info: Installation may take a while Error: ERROR: Failed to restore "stratixiv.qda" because some files could not be processed. Refer to "stratixiv.qdalog". Error: Failed to install stratixiv.qda -- make sure you specified a valid Quartus II Device Archive (.qda) file Error: Evaluation of Tcl script /tools/hw/quartus/10.1/quartus/common/tcl/apps/qpm/qinstall.tcl unsuccessful Error: Quartus II Shell was unsuccessful. 3 errors, 0 warnings Error: Peak virtual memory: 83 megabytes Error: Processing ended: Fri Dec 17 17:36:04 2010 Error: Elapsed time: 00:01:45 Error: Total CPU time (on all processors): 00:00:01 ////////////////////////////////////////////////////////////////////////////Link Copied
Wrong Forum. Please post this at a Quartus forum to get decent answers.
-Michael
Topic Options
