u-boot
I am trying to boot a kernel with u-boot, but don't seem to be getting anywhere. I've built u-boot from the nios2-generic branch according to http://nioswiki.com/dasuboot
It runs and things seem to basically work, including jffs2, but not ethernet.
What I am trying to do to test is:
1) program the kernel into flash with nios2-flash-programmer
2) load u-boot using nios2-download
3) boot the kernel image from flash
I've tried a few variations on this with the various images that are generated by the build. The last iteration went like this:
$ mkimage -A nios2 -O linux -T kernel -C none -a 0xc0000000 -e 0xc0000000 -n "linux" -d /data/nios/nios2-linux/uClinux-dist/linux-2.6.x/arch/nios2/boot/vmlinux.gz vmlinux.img Image Name: linux Created: Tue Mar 30 11:32:16 2010 Image Type: NIOS II Linux Kernel Image (uncompressed) Data Size: 4423821 Bytes = 4320.14 kB = 4.22 MB Load Address: 0xC0000000 Entry Point: 0xC0000000 $ bin2flash --base=0xc4000000 --end=0xc4ffffff --location=0x200000 --input=vmlinux.img --output=vmlinux.img.flash $ nios2-flash-programmer --mmu --base=0x4000000 vmlinux.img.flash --instance 1 $ nios2-download -g u-boot --instance 1 && nios2-terminal Using cable "USB-Blaster ", device 1, instance 0x01 Processor is already paused Initializing CPU cache (if present) OK Downloaded 153KB in 1.3s (117.6KB/s) Verified OK Starting processor at address 0xC1F80000 nios2-terminal: connected to hardware target using JTAG UART on cable nios2-terminal: "USB-Blaster ", device 1, instance 0 nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate) U-Boot ==> iminfo 0xc4200000 # # Checking Image at c4200000 ... Legacy image found Image Name: linux Image Type: NIOS II Linux Kernel Image (uncompressed) Data Size: 4423821 Bytes = 4.2 MB Load Address: c0000000 Entry Point: c0000000 Verifying Checksum ... OK ==> bootm 0xc4200000 # # Booting kernel from Legacy Image at c4200000 ... Image Name: linux Image Type: NIOS II Linux Kernel Image (uncompressed) Data Size: 4423821 Bytes = 4.2 MB Load Address: c0000000 Entry Point: c0000000 Verifying Checksum ... OK Loading Kernel Image ... OK OK bootargs=<NULL> @ 0xc1f3fd94 initrd=0x0-0x0
It doesn't do anything else after that. With this image I would expect it to start booting, then complain about a missing, like it does if I download the image directly ("Kernel panic - not syncing: No init found. Try passing init= option to kernel.").
With some other things I've tried, for example by using zImage, u-boot gives an error like this:
Loading Kernel Image ... OK OK bootargs=<NULL> @ 0xc1f3fd94 initrd=0x0-0x0 *** ERROR: unimplemented instruction @ c1700000 # ## ERROR# ## Please reset board# ##
I updated the git and wiki, and added a new page,
http://nioswiki.com/extrem_guide_to_kill_neek_with_u-boot
Please try again.
- Hippo
