Hello all,
how can I configurate and build the Linux for MAX10K family ? I use the kit BeMicro Max10, but it is not important. I would able to build uClinux for Cyclone III, Cyclone IV, when i use ptf file for menuconfig in 4-6 years old uclinux, but now ... i have sopcinfo and qsys, it is all. Thank you for answer. H. Naceradsky, Czech RepublicLink Copied
--- Quote Start --- how can I configurate and build the Linux for MAX10K family ? I use the kit BeMicro Max10, but it is not important. I would able to build uClinux for Cyclone III, Cyclone IV, when i use ptf file for menuconfig in 4-6 years old uclinux, but now ... i have sopcinfo and qsys, it is all. --- Quote End --- Please refer to the documents in https://rocketboards.org/foswiki/view/documentation/niosiilinuxusermanual . And also be aware that everything is not done automatically. Kazu- Mark as New
Thank you for your answer. It does not seem easy, but i try it.
Other way, is anywhere some java program for convert sopcinfo to ptf ?:) (i dont need the last version of linux) Honza- Mark as New
i was succesful only in few points, i downloaded from git reporitory sopc2dts and make sopc2dts.jar, which can convert sopcinfo to dts. I create directory /home/rocket_linux and create and downloaded /buildroot, /linux-socfpga and sourcery binary codebench lite 2014.05-17 and when i try to install, it finished with permission denied ... in picture. How continue ? I try in make nios2_defconfig in buildroot directory, make 3c120_defconfig in directory linux-socfpga and everything finished with error. Is somewhere described more details, how to setting the linux machine ? (i use linux, which i used for building uclinux for nios2 2-4 year ago... Thanks. Honza- Mark as New
--- Quote Start --- i was succesful only in few points, i downloaded from git reporitory sopc2dts and make sopc2dts.jar, which can convert sopcinfo to dts. I create directory /home/rocket_linux and create and downloaded /buildroot, /linux-socfpga and sourcery binary codebench lite 2014.05-17 and when i try to install, it finished with permission denied ... in picture. How continue ? I try in make nios2_defconfig in buildroot directory, make 3c120_defconfig in directory linux-socfpga and everything finished with error. Is somewhere described more details, how to setting the linux machine ? (i use linux, which i used for building uclinux for nios2 2-4 year ago... Honza --- Quote End --- Sorry, your JPEG veiw is too small and indistinct, so I can't read the error message. Kazu- Mark as New
it is strange, i included png about 99kB. So i wrote: $ /bin/sh sourgeryg++-2014.05-47-nios2-linux-gnu.bin Extracting installer ... Starting installer ... /tmp/sourgeryg++-2014.05-47-nios2-linux-gnu.bin_sfx.8a451e21/installer/jre/bin. ./lib/i386/client/libjvm.so: cannot restore segment prot after reloc: Permission denied. $ It was all ... how solve this error ? (i am not linux specialist) Thank you. Honza- Mark as New
--- Quote Start --- $ /bin/sh sourgeryg++-2014.05-47-nios2-linux-gnu.bin Extracting installer ... Starting installer ... /tmp/sourgeryg++-2014.05-47-nios2-linux-gnu.bin_sfx.8a451e21/installer/jre/bin. ./lib/i386/client/libjvm.so: cannot restore segment prot after reloc: Permission denied. $ It was all ... how solve this error ? (i am not linux specialist) --- Quote End --- Are you using SELinux? If so, please refer to the next pages http://www.cubrid.org/wiki_tutorials/entry/cannot-restore-segment-prot-after-reloc-permission-denied http://stackoverflow.com/questions/19223963/selinux-cannot-restore-segment-prot-after-reloc-permission-denied ... and so on. P.S. I'm also not a Linux specialist and I sometimes refer to web sites for Linux commands, for example http://bijo-linux.com/ (Sorry, Japanese only). (-: Kazu- Mark as New
Your JPEG veiw is too small and indistinct. Please, reupload it. Thank you
Topic Options
