hello,
sorry for the banal may request, I performed the procedure written on this site: http://www.nioswiki.com/linux/downloading_linux_distribution
"download http://www.niosftp.com/pub/linux/nios2-linux-20100621.tar"
PATH=$PATH:~/nios2-linux/toolchain-mmu/x86-linux2/bin
cd nios2-linux/uClinux-dist
make menuconfig
make
to compile uClinux on nios2? right? I have doubts that this way I also included the MMU ... thanks
Please... Help me
To use the MMU you of course need to use a NIOS FPGA designe with an MMU
At the moment there is a separate community based distribution / tool chain for "mak"ing the MMH-enabled Linux and standard apps. This is described in the WIKI. -Michael- Mark as New
--- Quote Start --- To use the MMU you of course need to use a NIOS FPGA designe with an MMU At the moment there is a separate community based distribution / tool chain for "mak"ing the MMH-enabled Linux and standard apps. This is described in the WIKI. -Michael --- Quote End --- Wondering if this process produces a S.O. with MMU?
