12745 Discussions
uClinux 3.7 libusb problems
I'm relatively new to Altera and uClinux and I've run into a problem trying to use libusb.
I currently have uClinux version 3.7.0 (git://sopc.et.ntust.edu.tw/git/linux-2.6.git) running on my DE2-115 board.
I would like to use libusb to simplify interaction with hot-pluggable USB devices. I have been unable to make the libusb source (libusbx-1.0.17) using the linux-mmu toolchain (git://sopc.et.ntust.edu.tw/git/toolchain-mmu.git).
I run into problems with udev when I try to configure with:
./configure --host=nios2-linux --disable-shared --enable-static --with-pci-ids-path=/home/jim/nios2-linux/uClinux-dist/user/pciutils --enable-debug LDFLAGS="-elf2flt=-s16000" CC=nios2-linux-gnu-gcc
my configure fails with:
checking libudev.h usability... yes
checking libudev.h presence... yes
checking for libudev.h... yes
checking for udev_new in -ludev... no
configure: error: "udev support requested but libudev not installed"
I have spent several days trying to compile and install udev (various versions from udev1.32 -> udev1.82) with the nios2-toolchain but have been unsuccessful.
Is anyone successfully using libusb on uClinux (with udev)
Any assistance would be great.
--- Quote Start ---
--- Quote End ---
I think this is only for NO MMU.
