uClinux FTP Question?
Hello I have a program that creates files, puts them into my //home/ftp directory. I would like to log into the FTP server and download those files that the program creates. I cant dowload or see anyfiles there, but I can upload files to that location.
How do I set up the permisions so I can see and download those through the FTP server?
copy '/bin/ls' to your ftp folder .
I'll give it a go! Thanks
I copied ls into my /home/ftp directory. However; it does not seem to do anything differntly. I suppose that was so that the ftp client could get a directory listing, but it still doesnt do that. Furthermore I still cannot actually download any files from that location even if I already "know" they exist there.
Any other sugestions?
BTW: the Default installation of my "Altera EPC12_eval" kit works just fine. I dont see how its so differnt. The rc file and other files in the /etc directory are nearly identical!?!
the default installation ./restore_my_flash thing does not have ls in the ftp directory. What are the differences in the /ftp setup?
Sorry , I said is not clear .
My English is not good, please forgives .
please see http://www.niosforum.com/forum/index.php?a...st=0&#entry8646 (http://www.niosforum.com/forum/index.php?act=st&f=18&t=2192&st=0&#entry8646)
this is my topic "a problem when using ftpd in passive mode ", which you send a reply for me .
I made an example for you .
You were on the right track it had to do with the ls, but putting ls in the ftp directory did nothing here is what I did.
I found that the default instalation worked. The default installation used the "ls" command from the busybox. I created a little script:
# !/bin/sh
/bin/busybox ls $*
that links the ls command back to the busybox, and I removed the ls.exe fromt the /bin directory.
This gave me the colored text back, and allowed my ftp client to "see" the files! (same as the default instalation)
Works prefectly now.
Thanks for the help!
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
You were on the right track it had to do with the ls, but putting ls in the ftp directory did nothing here is what I did.[/b]
--- Quote End ---
Sorry, I cannot understand the meaning of this sentence. My English is not good.
I enumerate some common questions about ftpd on uclinux . it maybe can help you .
first, you must change the terget dir of ftpd.
like the example which i give you.
open the /etc/passwd file .
and fix the ftp user &#39;s root dir.
===passwd=================================================
ftp:x:14:50:FTP User:/mnt/cf(<= /mnt is ramfs )
that&#39;s because the uclinux use romfs in the /home dir.
it no use to set the ftp dir to /home/ftp.
Second, you make sure that your ftp client software is run in port mode.
if run in pasive mode you will found the info from your ftp client software like this :
- PASV
- 227 Entering Passive Mode (0,0,0,0,12,1)
- Opening data connection IP: 0.0.0.0 PORT: 3073
- Unable connect to 0.0.0.0:3073 (Can&#39;t Assign Requested Address(10049))
there are four ZEROs when the server send his IP.
So, must use port mode without fix code of ftpd.
Good luck with you.
