uClinux and MAC opencore
Dear Sirs:
I am now trying to work with uClinux and MAC opencores but i have the following error when i try to generate the kernel:
include/nios2_system.h:48:2: warning:# warning Could not execute ...scripts/nios2_system.h/OpenCores_Ethernet_MAC.pm. I have seen there is such file and the content is:
package opencores_ethernet_mac;
use base qw(BasicModule);
use strict;
sub required_module_names {
("igor_mac")
sub required_class_name {
"opencores_ethernet_mac";
sub run {
opencores_ethernet_mac->run2 (@_);
1;
Any idea about what is going wronly?.
Jorge
Can you send me the system PTF file that you're building the kernel against via e-mail? I'll see if I can reproduce the problem
ken.wong@microtronix.com
Hi Jorge, I tried compiling a kernel using the PTF file you provided and I didn't have any problems creating the nios2_system.h file. There were no# warning pre-processor directives within the file.
Could you e-mail me the results of your kernel build using the original "opencores_ethernet_mac.pm" file (instead of using the one that you modified). I need more context surrounding the# warning message that you got.
One other question... Are you using the Opencores.org Ethernet MAC that we provide? Or did you get yours from somewhere else? I only ask because there were some differences in how the opencores_ethernet_mac name was spelled out in your PTF file than from what we provide in our kits.
Hello Ken:
I am afraid i got it from somewhere else not from Microtronix. It works with NIOS II and Lightweight IP and i though it could work with linux.
However, could i test the Microtronix Opencores?. Could you send it to me?.
Jorge Domingo
You should take a look at our website for more information regarding our Opencores.org EMAC development kit.
Although in all honesty, I don't know if it's the component itself that's causing problems. Were there any other difficulties when you were installing the Nios II Linux Distribution that you can think of?
Hello:
I don´f find any other error in fact if i strip away the opencores option in the kernel menu I am able to generate a binary file if i tick again the opencores option the same error come up:
Microtronix Linux Extensions
Version 1.4, Built June 20, 2005
make: Entering directory `/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x'
no emulation specific options.
Using /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x as source for kernel
GEN /cygdrive/c/altera/kits/nios2/bin/eclipse/workspace/linuxdb/build/Makefile
CHK include/linux/version.h
CHK include/nios2_system.h
Error message follows:
Undefined subroutine &OpenCores_Ethernet_MAC::run called at (eval 1) line 1, <STDIN> line 3372.
HOSTCC scripts/basic/fixdep
etc...
Jorge
It still looks like a case issue. Try renaming the opencores_ethernet_mac.pm file so that it matches the output you see in your kernel build.
You&#39;ll also need to go through the opencores_ethernet_mac.pm file and fix any case issues in there as well... I&#39;m afraid this is as far as I can take this issue. We only guarantee that the opencores emac driver we package up works with our Opencore EMAC package.
