uClinux boot routine
I'm just curious about the boot process of uClinux on my NIOSII board. I'm downloading
the zImage over the NIOSII command shell: nios2-download -g
What is the relation between the bootloader and the zImage file and whats with the -g
parameter in the command?
Would like to explain this part in my documentation and would appreciate if somebody
could give some comments.
Thanks again,
Roman
-g just says nios2-download to start the CPU after the download. If you omit -g, nios2-download will load the elf file in memory, but leave the CPU in a paused state.
--- Quote Start ---
whats with the -g parameter in the command?
--- Quote End ---
nios2-download --help
-Michael
Thx for replies.
So where is the zImage file stored when I'm downloading with this methode to the board?
Roman
The elf file itself contains the address at which the data should be uploaded.
thanks a lot
