uClinux mounting problem
Hi all,
I got problem when trying to mount a Linux PC to a local folder of Cyclone (/var) .
Here are the steps performed :
(the kit I'm using is cyclone 1c12 eval edition
1) Log in uClinux on Cyclone
2) Setup an IP for the Cyclone : ifconfig eth0 192.168.1.20 netmask 255.255.255.0
3) Setup the IP for the Linux PC (Assuming : 192.168.1.19
4) In Linux PC , Setup NFS shares by opening file /etc/exports (under ROOT) and add the following command :
/home/mymnt 192.168.1.20(rw)
5) Start NFS server : $ /etc/init.d/nfs start
6) Mount the Linux PC : mount –t –n nfs 192.168.1.19:/home/mymnt /var
After completing 6) , the following error occurred :
can't create lock file /etc/mtab~25: read-only file system (use -n flag to override)
I think the cause of the error is /etc folder (on cyclone) is READ-ONLY , so , uClinux cannot create mtab~25 on it. How can I "forward" the creation of mtab~25 to a writable folder such as /var , /usr ?
OneNet
Hi OneNet,
Add an empty file: /etc/mtab to your file system -- then try again -- this was all I needed.
--Scott
Hi Scott,
As I mentioned , the folder /etc on Cycloneis READ-ONLY.
(mtab~25 is created at runtime)
Thank you so much,
OneNet
As the mount command told you: add the -n flag to your mount command. That way it doesn't try to write to the /etc/mtab file but mounts anyway.
Hi Onenet,
And as I mentioned, adding /etc/mtab to the filesystem worked for me. The problem
I observed was related to locking /etc/mtab. The fact that the filesystem
was readonly was irrelevant.
--Scott
Hi wqoossens ,
I already used -n flag in the above commands.
OneNet
Hi Scott ,
I added mtab and fstab to /etc of the Cyclone uClinux filesystem (I added fstab since if I I had added mtab ONLY , uClinux would have asked me for fstab
Here are the contents of both mtab and fstab
portmap:192.168.1.19
lockd:192.168.1.19
rquotad:192.168.1.19
mountd:192.168.1.19
statd:192.168.1.19
where 192.168.1.19 is the IP of Linux PC
I think these files set the connection TO the Linux PC we want to mount. (?????)
Also , I have added a step :
4a) In Linux PC , open /etc/hosts.allow as ROOT and add the following to the file :
portmap:192.168.1.20
lockd:192.168.1.20
mountd:192.168.1.20
statd:192.168.1.20
where 192.168.1.20 is the Cyclone IP
(the content of hosts.allow accepts the connection from the machines in the list)
At step 6), run the command :
mount 192.168.1.19:/home/mymnt /var
The following error occurred :
mount: rpc: port mapper failure - rpc: unable to receive
About this error , I thaught that I "opened" connection between Linux PC (/etc/hosts.allow) and Cyclone (fstab , mtab). Do I have a lack of some step ?
What do you think ?
OneNet
Hi Scott,
I have tried solutions in the 2 links from you but still not be able to mount a Linux PC.
By the way , do you know how to bring in the portmapper from the uCLinux CVS as NateCain mentioned in the second link (http://www.niosforum.com/forum/index.php?a...1543&hl=portmap) ?
OneNet
Hi Onenet,
Use CVS to checkout the portmap code from the CVS repository.
--Scott
