uart hal questions ?
1. how can I open the uart for non blocking read ?
2. how can I do "blocking output" with "non blocking read" ?
( without modifying altera_avalon_uart.c)
3. how can I disable RTS/CTS in software ?
1. without OS a blocking uart read is not very usefull
I open the uart in the following way:
int fdterm; // FILEDESCRIPTOR RETURNED BY OPEN
FILE *fpterm; // FILEPOINTER RETURNED BY FDOPEN
flags= O_RDWR | O_NONBLOCK | O_NOCTTY;
fdterm = open(devicename,flags);
if(fdterm==0) {
DPRINTF("ERROR open devive:%s\r\n",devicename);
return -1;
fpterm=fdopen(fdterm,"rw+");
if(fpterm==0) {
DPRINTF("ERROR fdopen devive:%s\r\n",devicename);
// then I can read nonblocking
res=read(fdterm,uart1_tempbuff,sizeof(uart1_tempbuff)-1);
if(res>0) {
// we have receuived any characters
2. using fprintf(fpterm,"...") I get scrambled output
I think this is because in "altera_avalon_uart.c" in
function alt_avalon_uart_write the buffer is overwritten. I get
correct output, if I set disable "no_block=0"
int alt_avalon_uart_write (alt_fd* fd, const char* ptr, int len)
alt_irq_context context;
int no_block;
alt_u32 next;
alt_avalon_uart_dev* dev = (alt_avalon_uart_dev*) fd->dev;
int count = len;
* Construct a flag to indicate whether the device is being accessed in
* blocking or non-blocking mode.
no_block = (fd->fd_flags & O_NONBLOCK);
no_block=0; // set no_block to 0 to get printf working
3. I have configured the uart in sopc builder with RTS/CTS
but don't want to use it in software.
I use the following function to clear the flag ALT_AVALON_UART_FC.
int uart_set_flowcontrol(int filedescriptor,BYTE flowctrl) {
alt_fd* fd;
alt_avalon_uart_dev* dev; // pointer to uart device
if(filedescriptor<0) return -1;
// see alt_ioctrl.c
fd = (filedescriptor < 0) ? NULL : &alt_fd_list[filedescriptor];
if (fd) {
dev=(alt_avalon_uart_dev*)fd->dev;
if(flowctrl) {
dev->flags|=ALT_AVALON_UART_FC;
else {
dev->flags&=~ALT_AVALON_UART_FC;
return 0;
return -1;
4. I change baudrate with the function
int uart_set_baudrate(int filedescriptor,int baudrate) {
struct termios term;
int res;
res=ioctl(filedescriptor,TIOCMGET,&term);
if(res<0) {
DPRINTF("ERROR ioctl filedescriptor:%d\r\n",filedescriptor);
return res;
term.c_ispeed=baudrate;
term.c_ospeed=baudrate;
res=ioctl(filedescriptor,TIOCMSET,&term);
if(res<0) {
return res;
is this correct ???
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
1. how can I open the uart for non blocking read ?[/b]
--- Quote End ---
As you put it in your example, this opens the UART non-blocking
--- Quote Start ---
2. how can I do "blocking output" with "non blocking read" ?[/b]
--- Quote End ---
Open it twice i.e.
int fdterm; // NON BLOCKING FILEDESCRIPTOR RETURNED BY OPEN
int fdterm_block; // BLOCKING FILEDESCRIPTOR RETURNED BY OPEN
flags= O_RDWR | O_NOCTTY;
fdterm_block = open(devicename,flags);
Use the appropriate handle depending upon whether you want blocking or non-blocking behaviour
--- Quote Start ---
3. how can I disable RTS/CTS in software ?[/b]
--- Quote End ---
You can&#39;t it&#39;s asssumed that if you selected this hardware in SOPC Builder you will want the software. If you don&#39;t want RTS CTS turn it off in SOPC builder and save yourself some hardware resources
thanks rugbybloke,
the question of RTS/CTS is just that I don&#39;t know, if I will
need it later. Also I have 3 nearly equal projects, so that
I don&#39;t want to change the sopc system.
So I think, it only needs to clear the flag ALT_AVALON_UART_FC.
Is the function "uart_set_flowcontrol correct" ???
The function looks OK to me, but try it.
I can&#39;t seem to get the &#39;open&#39; command to work, only the &#39;fopen&#39; one which doesn&#39;t seem to support non-blocking access. What include files are you using?
Richard
The best way to find things like this is to use man on a unix machine, or type "linux man open" into google.
i think open is in <fcntl.h>, don&#39;t know if you need all, just a copy from my file
# include <sys/ioctl.h>
// open ???# include <fcntl.h># include<string.h>
// rand(),srand()# include<stdlib.h>
// write(),read(),usleep()# include<unistd.h>
# include <priv/alt_file.h># include "altera_avalon_uart_regs.h"# include "altera_avalon_uart.h"
# include<time.h>
