uboot uclinux boot
hi all,
I am tring to boot uclinux-1.3 from u-boot-1.1.3 on altera 2s60 board.
I can download and boot uboot on the board sucessfully and also uclinux-1.3 by directly downloading into sdram or buring vmlinux.img file into flash through quratus flash programmer.
Both, u-boot and uclinux are fine individually..... http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
The problem which I am facing is when I try to boot my vmlinux.img ( maked through mkimage utility with -a 0x01000000 -e 0x01000000) ..... the terminal is totally blank .......
seems like linux never gets control (executed) once u-boot passes control to location 0x01000000 (linux kernel entry address).
I tried keeping LED blinking code (tested in linux as well as u-boot) in my head.S file of linux which will blink 3 leds on the board and its not happening which means linux never got executed.
I am confirm about u-boot passing control to memory address 0x01000000 as my prints are there in bootm command source code after disabling interrupt and before calling (kernel) ();
My question to the forum is ... Is there any one who has booted any linux from any u-boot ever on any altera board.
I have searched on the nios forum for same but all the discussions were over with incomplete state or any success in this area is never submitted on web or any forum.
Can any one suggest me some solutions or share his/her experince over similar issue. Or please direct me to proper links if some details are given on web.
Any Reply or Help is highly appreciated
thanks in advance
Ankur Maheshwari
Hello,currently I am working on porting uclinux and uboot on my Cyclone board and I ported uClinux and uboot on Samsung&#39;44b0 board some time ago. I have a question to ask, before uploading our kernel image to the board, we must build a niosCPU and download it to the board? Or can you give me some detailed file on porting uclinux to nios board?
Thank you in advance
my e-mail is : scut_ak@163.com
--- Quote Start ---
originally posted by ankur@Apr 20 2006, 05:51 AM
hi all,
i am tring to boot uclinux-1.3 from u-boot-1.1.3 on altera 2s60 board.
i can download and boot uboot on the board sucessfully and also uclinux-1.3 by directly downloading into sdram or buring vmlinux.img file into flash through quratus flash programmer.
both, u-boot and uclinux are fine individually..... http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/smile.gif
the problem which i am facing is when i try to boot my vmlinux.img ( maked through mkimage utility with -a 0x01000000 -e 0x01000000) ..... the terminal is totally blank .......
i tried keeping led blinking code (tested in linux as well as u-boot) in my head.s file of linux which will blink 3 leds on the board and its not happening which means linux never got executed.
i am confirm about u-boot passing control to memory address 0x01000000 as my prints are there in bootm command source code after disabling interrupt and before calling (kernel) ();
my question to the forum is ... is there any one who has booted any linux from any u-boot ever on any altera board.
i have searched on the nios forum for same but all the discussions were over with incomplete state or any success in this area is never submitted on web or any forum.
can any one suggest me some solutions or share his/her experince over similar issue. or please direct me to proper links if some details are given on web.
any reply or help is highly appreciated
thanks in advance
ankur maheshwari
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14504)
--- quote end ---
--- Quote End ---
To Ankur,
Please give how you mkimg, bootm, and u-boot log messages. Let forum see what happens .
--- Quote Start ---
originally posted by mountain8848@Apr 20 2006, 08:05 AM
to ankur,
please give how you mkimg, bootm, and u-boot log messages. let forum see what happens .
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14511)
--- quote end ---
--- Quote End ---
OK..
I am building my uclinux in linux environment
For mkimg ......
objcopy -O binary vmlinux vmlinux.bin
gzip -9 vmlinux.bin
mkimage - A nios2 -O linux -T kernel -C gzip -a 01000000 -e 01000000 -n &#39;linux-2s60es&#39; -d vmlinux.bin.gz vmlinux.img
for bootm
I download my vmlinux.img at 01000000 and my file system at 01900000 (file system I image I have taken form nios-II ide)
then
bootm 01000000 01900000
then prints comes which is between disable_interrupt and kernel(); call (I have used ppc kernel function call).
"Transferring control to Linux at ......."
After this print screen goes blank
thanks
Ankur
--- Quote Start ---
hi scut,
Till now I have worked on 1s40es and 1s60es development kits, which comes along quartus and nios ide software cds. We have build our niosCPU (fpga image file OR .sof) file through quartus-II 4.2 and for compiling my linux I have used same installation in linux system or we can build our linux with nios ide s/w.
thanks
Ankur
Hi Ankur,
> gzip -9 vmlinux.bin
Since you&#39;re using a compressed kernel ...
... you need to load the image somewhere else. Otherwise, u-boot will decompress
the kernel over the compressed image (the compressed image gets corrupted).
Try downloading the image to a higher address, say 0150_0000 or something.
Then when it is decompressed to 0100_0000 you won&#39;t have any overlap.
Specifying a ramdisk using the bootm command won&#39;t work. The kernel doesn&#39;t
accept parameters from the bootloader. You&#39;ll have to use another technique.
> altera board.
Yes, there are many people who used u-boot to with several versions of linux
(and ecos) on a variety of altera (and custom) boards. Don&#39;t get frustrated,
you&#39;re very close to success :-)
--Scott
hi Scott,
thanks for the info, my load address for kernel image is 0130_0000, mistakenly I wrote 0100_0000.
I have noted down bootm limitation also.
I will update the forum as soon as I get any success.
thanks once again
Ankur Maheshwari
--- Quote Start ---
originally posted by smcnutt@Apr 20 2006, 09:55 AM
hi ankur,
> gzip -9 vmlinux.bin
> mkimage - a nios2 -o linux -t kernel -c gzip -a 01000000 -e 01000000 -n
since you&#39;re using a compressed kernel ...
> i download my vmlinux.img at 01000000
... you need to load the image somewhere else. otherwise, u-boot will decompress
try downloading the image to a higher address, say 0150_0000 or something.
then when it is decompressed to 0100_0000 you won&#39;t have any overlap.
specifying a ramdisk using the bootm command won&#39;t work. the kernel doesn&#39;t
accept parameters from the bootloader. you&#39;ll have to use another technique.
> altera board.
yes, there are many people who used u-boot to with several versions of linux
(and ecos) on a variety of altera (and custom) boards. don&#39;t get frustrated,
regards,
--scott
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14517)
--- quote end ---
--- Quote End ---
