uboot + uclinux + nios2
Geehrter Beitragender II
1.224Aufrufe
I compiled uboot as well as uclinux for stratix board DK1S40 using standard hardware design for nios2 that comes with web addition software from altera.
when I tried to create an uImage ...running this command.
./mkimage -A nios2 -O linux -T kernel -C gzip -a 0x01000000 -e 0x01000000 "uclinux kernel Image" -d linux.bin.gz uImage
I got an error message........
Invalid CPU Type - valid names are: alpha, arm, x86, ia64, m68k, microblaze, mips, mips64, ppc, s390, sh, sparc, sparc64
Usage: ./mkimage -l image
-l ==> list image header information
./mkimage [-x] -A arch -O os -T type -C comp -a addr -e ep -n name -d data_file[:data_file...] image
-A ==> set architecture to 'arch'
-O ==> set operating system to 'os'
-T ==> set image type to 'type'
-C ==> set compression type 'comp'
-a ==> set load address to 'addr' (hex)
-e ==> set entry point to 'ep' (hex)
-n ==> set image name to 'name'
-d ==> use image data from 'datafile'
-x ==> set XIP (execute in place)
when I looked at the mkimage source code file....I found the nios2 stuff is missing.......
I would really appreciate if someone help me to resolve this issue.
Is anyone knows ......what needs to be done in order to create an uImage for nios2 platform.
1 Antworten
466Aufrufe
Hi haq,
You need to get the latest version of tools/mkimage.c (revision 1.15).
You're probably using mkimage revision 1.14 (from the u-boot 1.1.2 tarball).
Download this file from sourceforge & rebuild.
Otherwise, you can get a pre-built version of mkimage from:
http://www.psyent.com/download (http://www.psyent.com/download
--Scott
Antworten
