uclinux kernel panic
hi,
If anyone knows how to resolve this ...kernel panic......issue....here is the error message......
debian-dell-p3:~# kermit -c
Connecting to /dev/ttyS0, speed 115200
Escape character: Ctrl-\ (ASCII 28, FS): enabled
Type the escape character followed by C to get back,
or followed by ? to see other options.
Using MAC Address 00:07:FFFFFFED:0C:04:FFFFFFBD
host 10.0.0.1 is alive
DK1S40 ==> bdinfo
mem start = 0x01000000
mem size = 0x01000000
flash start = 0x00000000
flash size = 0x00800000
flash offset= 0x00000000
sram start = 0x02000000
sram size = 0x00100000
ethaddr = 00:07:ED:0C:04:BD
ip_addr = 10.0.0.51
baudrate = 115200 bps
DK1S40 ==> setenv bootfile /tftpboot/uImage
DK1S40 ==> printenv
baudrate=115200
ethaddr=00:07:ed:0c:04:bd
ipaddr=10.0.0.51
serverip=10.0.0.1
netmask=255.0.0.0
stdin=serial
stdout=serial
stderr=serial
bootfile=/tftpboot/uImage
Environment size: 162/65532 bytes
DK1S40 ==> setenv bootargs root=/opt/nios2development rw nfsroot=10.0.0.1:/tftpboot/10.0.0.51
DK1S40 ==> printenv
baudrate=115200
ipaddr=10.0.0.51
serverip=10.0.0.1
netmask=255.0.0.0
stdin=serial
stdout=serial
stderr=serial
bootargs=root=/opt/nios2development rw nfsroot=10.0.0.1:/tftpboot/10.0.0.51
Environment size: 238/65532 bytes
DK1S40 ==> saveenv
Saving Environment to Flash...
Un-Protected 1 sectors
Erasing Flash...
Erased 1 sectors
Writing to Flash... done
Protected 1 sectors
DK1S40 ==> tftpboot 1100000 uImage
TFTP from server 10.0.0.1; our IP address is 10.0.0.51
Filename 'uImage'.
Load address: 0x1100000
Loading:# ################################################################# ################################################################# #########
done
Bytes transferred = 715524 (aeb04 hex)
DK1S40 ==> imi 1100000
# # Checking Image at 01100000 ...
Image Name: Linux Kernel Image
Image Type: Nios-II Linux Kernel Image (gzip compressed)
Data Size: 715460 Bytes = 698.7 kB
Load Address: 01000000
Entry Point: 01000000
Verifying Checksum ... OK
DK1S40 ==> bootm 1100000# # Booting image at 01100000 ...
Uncompressing Kernel Image ... OK
Linux version 2.6.11-uc0-barco1 (root@debian-dell-p3) (gcc version 3.4.3 (Barco Control Rooms))# 2 Sat Jul 2 11:40:34 EDT 2005
uClinux/Nios II
Altera Nios II support © 2004 Microtronix Datacom Ltd.
Built 1 zonelists
Kernel command line: CONSOLE=/dev/ttyS0 noinitrd ip=bootp root=/dev/nfs rw
PID hash table entries: 128 (order: 7, 2048 bytes)
Console: colour dummy device 80x25
Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
Memory available: 14464k/16384k RAM, 0k/0k ROM (1524k kernel code, 215k data)
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
NET: Registered protocol family 16
devfs: 2004-01-31 Richard Gooch (rgooch@atnf.csiro.au
devfs: devfs_debug: 0x0
devfs: boot_options: 0x1
NIOS serial driver version 0.0
ttyS0 (irq = 4) is a builtin NIOS UART
io scheduler noop registered
io scheduler cfq registered
smc_probe: 50000 Khz Nios
SMSC LAN91C111 Driver (v2.1), (Linux Kernel 2.6)
eth0: SMC91C11xFD(rev:1) at 0x82110300 IRQ:6 MEMSIZE:8192b NOWAIT:0 ADDR: 00:07:ed:0c:04:bd
NET: Registered protocol family 2
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP established hash table entries: 1024 (order: 1, 8192 bytes)
TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
TCP: Hash tables configured (established 1024 bind 1024)
NET: Registered protocol family 17
eth0:PHY 100BaseT
eth0:PHY Full Duplex
Sending BOOTP requests . OK
IP-Config: Got BOOTP answer from 10.0.0.1, my address is 10.0.0.51
IP-Config: Complete:
device=eth0, addr=10.0.0.51, mask=255.0.0.0, gw=10.0.0.1,
host=nios2, domain=nios2.net, nis-domain=(none),
bootserver=10.0.0.1, rootserver=10.0.0.1, rootpath=/opt/nios2development
Looking up port of RPC 100003/2 on 10.0.0.1
Looking up port of RPC 100005/1 on 10.0.0.1
VFS: Mounted root (nfs filesystem).
mount_devfs_fs(): unable to mount devfs, err: -2
Freeing unused kernel memory: 68k freed (0x1190000 - 0x11a0000)
Warning: unable to open an initial console.
Kernel panic - not syncing: No init found. Try passing init= option to kernel.
Looks like you're trying to use DEV_FS and it can't mount itself. Since you're using a romfs partition, my first guess is that the /dev directory doesn't exist and the DEV_FS subsystem can't create it. So try adding /dev to your fs, re-build, re-upload the filesystem, and try again.
Hi, how do you build a cross compiler environment in linux host pc? Please give us some tips/steps.
what is kermit -c in ?
debian-dell-p3:~# kermit -c Connecting to /dev/ttyS0, speed 115200 Escape character: Ctrl-\ (ASCII 28, FS): enabled
