Error: expected comma after "break"[/cygdrive/d/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/arch/nios2nommu/kernel/entry.S] kernel_0518 line 897
Error: expected comma after "nobreak"[/cygdrive/d/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/arch/nios2nommu/kernel/entry.S] kernel_0518 line 43 in entry.s , there wasn't any comma after break and nobreak. i setuped uclinux1.3 again, the error still in . why ? thanks!!!Link Copied
setup niosii 1.1 evaluation, it's OK http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
Wich kind of configuration you had to do ???
I'm getting the same problem here.- Mark as New
Anyone know what to do to make it work properly ??
I had to put a comment in front of the line: // .set nobreak // .set break then it builted all the way to the end, but if it is in there, is because it do something, right ?? http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif And I don't want to miss it, so, any ideas ? What did gwbing ???- Mark as New
Try ,0 after those lines.
The problem is your nios2-elf gnu tool chain does not support those assembler directives. You can download the latest toolchain from Altera or comment those lines out of entry.S. It does not hurt to comment those lines out for the older tool chain.
