ucosII and lwip
Hi,everyone.
Who knows the limitations of NiosII evaluation ?
When I build the software temple of simple Socket Sever in NiosII 1.1 evaluation,it appears this error:
Error *** No rule to make target `D:/altera/kits/nios2/components/micrium_uc_osii/build/app.mk'. Stop.
Error D:/altera/kits/nios2/components/micrium_uc_osii/build/app.mk: No such file or directory makefile simple_socket_server/Debug line 63
And another problerm is :
I use NiosII 1.0(not evaluation) to build Hello ucosII temple which carried by itself .It also has problem as:
Error *** [ext_flash.flash] Error 5 hello_ucosii_0
elf2flash: Error generating Flash file, exiting[Jun 27,
elf2flash: Error reading boot copier[Jun 27, 2005 2]
Please give me some advice .Thank you!!!!!!!!
My QQ:332418170
Hi
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
elf2flash: Error reading boot copier[Jun 27, 2005 2][/b]
--- Quote End ---
Let check What is Memory module for Reset Address on more "cpu" setting in SOPC Builder.
As i know, if memory module was not flash device, maybe you get above error message.
Glen
--- Quote Start ---
Hi,everyone.
Error *** No rule to make target `D:/altera/kits/nios2/components/micrium_uc_osii/build/app.mk&#39;. Stop.
My QQ:332418170[/b]
--- Quote End ---
It&#39;s quite simple the eval copy of Nios does not contain MicroC/OS-II, so you&#39;re not going to have any look getting the LWIP/MicroC/OS-II examples running
