__ucosii__ not defined
Hello Guru's,
I need to create a library project using the NIOS2 IDE. I started by creating a new project and selected the Altera NIOS II -> Managed Library Project. Added a dependency to the syslib. However when I build the library, it seems that __ucosii__ is not defined (the same code was previously part of an application but must be separated into a lib now). Is this define not set by default for library projects or am I missing something else?
/M.
--- Quote Start ---
originally posted by bokkie@Jan 10 2007, 05:09 AM
hello guru's,
i need to create a library project using the nios2 ide. i started by creating a new project and selected the altera nios ii -> managed library project. added a dependency to the syslib. however when i build the library, it seems that __ucosii__ is not defined (the same code was previously part of an application but must be separated into a lib now). is this define not set by default for library projects or am i missing something else?
regards,
/m.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=20467)
--- quote end ---
--- Quote End ---
M.
When you create the New System Library you have a choice at that time select MicroCOSII.
BTW - Use File->New->Project then select Altera NiosII->NiosII System Library
Mike
