unable to load cramfs
hello friends
i am using cramfs .i have compressed kernel .
i have stored u-boot at 0x0 ,cramfs at 0x00100000 and kernel image at 0x00020000.
my flash is 2MB(0x00000000 to 0x00200000).and sdram is 8Mb(0x00800000 to 0x00f00000).
but when give command " bootm 0x0002000" on hyperterminel then i get o/p on console like:
uClinux/Nios II
Altera Nios II support © 2004 Microtronix Datacom Ltd.
Built 1 zonelists
Kernel command line: root=/dev/mtdblock0 ro
PID hash table entries: 64 (order: 6, 1024 bytes)
Dentry cache hash table entries: 2048 (order: 1, 8192 bytes)
Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
Memory available: 6948k/8192k RAM, 0k/0k ROM (883k kernel code, 241k data)
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
Linux NoNET1.0 for Linux 2.6
Serial: JTAG UART driver $Revision: 1.4 $
ttyJ0 at MMIO 0x80220820 (irq = 1) is a jtag_uart
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered
RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize
ALTERA map: Found 1 x16 devices at 0x0 in 16-bit bank
Amd/Fujitsu Extended Query Table at 0x0040
number of CFI chips: 1
cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
cmdlinepart partition parsing not available
RedBoot partition parsing not available
Using up3 development partition definition
Creating 2 MTD partitions on "ALTERA":
0x00100000-0x00200000 : "romfs"
0x00000000-0x00100000 : "loader/kernel"
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(31,0)
Hi slsnios,
There are many possible causes.
First, make sure you don't have the broken cramfs code. See:
http://forum.niosforum.com/forum/index.php...=2383&hl=cramfs (http://forum.niosforum.com/forum/index.php?showtopic=2383&hl=cramfs
Once you're sure your cramfs code is clean, you might want to enable jffs2/cramfs support in
u-boot. This will allow you to list and load jffs2/cramfs files into ram and view some file system
information -- it's a good way to ensure you have a clean filesystem image _before_ you boot
the kernel.
And, of course, double-check your kernel configuration to ensure you have cramfs support
enabled ;-)
--Scott
--- Quote Start ---
originally posted by smcnutt@Jun 30 2006, 06:07 PM
hi slsnios,
> kernel panic - not syncing: vfs: unable to mount root fs on unknown-block(31,0)
there are many possible causes.
first, make sure you don't have the broken cramfs code. see:
once you're sure your cramfs code is clean, you might want to enable jffs2/cramfs support in
u-boot. this will allow you to list and load jffs2/cramfs files into ram and view some file system
the kernel.
and, of course, double-check your kernel configuration to ensure you have cramfs support
enabled ;-)
regards,
--scott
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16571)
--- quote end ---
--- Quote End ---
hi scott
thans
but
i have already changed cramfs code.
i selected cramfs option.
i checked image of cramfs which is genereted by mkcram command.
now i got sam problem..
please help me,what should be my next step?
Hi slsnios,
Try adding the following to the kernel command line:
rootfstype=cramfs
--Scott
--- Quote Start ---
originally posted by smcnutt@Jul 7 2006, 02:04 AM
hi slsnios,
try adding the following to the kernel command line:
rootfstype=cramfs[/b]
--Scott
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16692)
--- Quote End ---
[/b]
--- Quote End ---
Thanks scott
but can you tell me where i have to insert tis line at source code or project folder ,..where is kernel command line..
--- Quote Start ---
originally posted by slsnios+jul 7 2006, 04:45 pm--><div class='quotetop'>quote (slsnios @ jul 7 2006, 04:45 pm)</div>
--- quote start ---
<!--quotebegin-smcnutt@Jul 7 2006, 02:04 AM
hi slsnios,
--Scott
--- Quote End ---
[/b]
--- Quote End ---
Thanks scott
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16704)</div>
[/b]
--- Quote End ---
In kernel menuconfig,
Processor type and features --> () Default kernel command string
root=/dev/mtdblock0 ro rootfstype=cramfs
TO_BE_DONE
Hi slsnios,
> ./mkcramfs -n cramfs -z -r ./dir cramfs.img
> then it is giving following error,
... snip ...
> cramfs.img: invalid cramfs--wrong magic
You&#39;re reversing the endian order (-r option) & cramfschk does not have similar option. Endian
order reversal should not be necessary.
--Scott
hi scott
so,am i wrong or right?
where am i doing mistake ?
with regard
slsnios
Hi slsnios,
If you&#39;re creating the cramfs image on a little endian machine (like a PC) don&#39;t use the -r option.
--Scott
hi scott
so much thanks.......infinite
atleast ,now kernel is able to find which is fs is there.
but still now i have problem
now, i got massegs on terminal like
uClinux/Nios II
Built 1 zonelists
Memory available: 7040k/8192k RAM, 0k/0k ROM (800k kernel code, 235k data)
ttyJ0 at MMIO 0x80221080 (irq = 1) is a jtag_uart
UP3 map: Found 1 x16 devices at 0x0 in 16-bit bank
Using altera development partition definition
Creating 2 MTD partitions on "altera map":
VFS: Mounted root (cramfs filesystem) readonly.
Freeing unused kernel memory: 48k freed (0x8e4000 - 0x8ef000)
Warning: unable to open an initial console.
Kernel panic - not syncing: No init found. Try passing init= option to kernel.
if i think init is not there ,then it should be not worked when same fs is used as romfs.bin
because i got kernel o/p ,when i used same fs without compress as romfs.
please help me.
Hi slsnios,
Great!
You should forget about romfs.bin and just populate the cramfs with the necessary files -- and
edit the init scripts to suit your own needs. Here&#39;s what I typically use:
d 0700 176 500:245 root
d 0700 1700 500:245 root/bin
f 0755 54448 500:245 root/bin/agetty
f 0755 77640 500:245 root/bin/arp
f 0755 61804 500:245 root/bin/badblocks
f 0755 1712 500:245 root/bin/basename
f 0755 122012 500:245 root/bin/boa
f 0755 6348 500:245 root/bin/cat
f 0755 34476 500:245 root/bin/chattr
f 0755 30976 500:245 root/bin/chgrp
f 0755 22936 500:245 root/bin/chmod
f 0755 31200 500:245 root/bin/chown
f 0755 24464 500:245 root/bin/cmp
f 0755 26432 500:245 root/bin/cp
f 0755 12612 500:245 root/bin/date
f 0755 27156 500:245 root/bin/dd
f 0755 24940 500:245 root/bin/debug
f 0755 25500 500:245 root/bin/df
f 0755 92968 500:245 root/bin/dhcpcd
f 0755 1536 500:245 root/bin/dirname
f 0755 1340 500:245 root/bin/echo
f 0755 111752 500:245 root/bin/ex1
f 0755 111968 500:245 root/bin/ex2
f 0755 113920 500:245 root/bin/ex3
f 0755 112092 500:245 root/bin/ex4
f 0755 111820 500:245 root/bin/ex5
f 0755 111828 500:245 root/bin/ex6
f 0755 112356 500:245 root/bin/ex7
f 0755 1008 500:245 root/bin/false
f 0755 58996 500:245 root/bin/fbset
f 0755 113208 500:245 root/bin/fdisk
f 0755 27888 500:245 root/bin/free
f 0755 58340 500:245 root/bin/fsck
f 0755 107260 500:245 root/bin/ftpd
f 0755 30840 500:245 root/bin/grep
f 0755 5820 500:245 root/bin/hostname
f 0755 25940 500:245 root/bin/ifattach
f 0755 78852 500:245 root/bin/ifconfig
f 0755 38292 500:245 root/bin/inetd
f 0755 23904 500:245 root/bin/kill
f 0755 29780 500:245 root/bin/l
f 0755 24224 500:245 root/bin/ln
f 0755 27588 500:245 root/bin/login
f 0755 13304 500:245 root/bin/logname
f 0755 42648 500:245 root/bin/ls
f 0755 35972 500:245 root/bin/lsattr
f 0755 2108 500:245 root/bin/mkdir
f 0755 1728 500:245 root/bin/mkfifo
f 0755 3820 500:245 root/bin/mknod
f 0755 26860 500:245 root/bin/more
f 0755 153200 500:245 root/bin/mount
f 0755 26968 500:245 root/bin/mv
f 0755 24216 500:245 root/bin/pause
f 0755 63200 500:245 root/bin/ping
f 0755 1536 500:245 root/bin/printenv
f 0755 36728 500:245 root/bin/ps
f 0755 4304 500:245 root/bin/pwd
f 0755 25580 500:245 root/bin/reboot
f 0755 2164 500:245 root/bin/rm
f 0755 2036 500:245 root/bin/rmdir
f 0755 81440 500:245 root/bin/route
f 0755 88108 500:245 root/bin/sash
f 0755 54596 500:245 root/bin/sh
f 0755 21436 500:245 root/bin/shutdown
f 0755 23096 500:245 root/bin/sigpending
f 0755 24904 500:245 root/bin/sigsuspend
f 0755 57332 500:245 root/bin/stty
f 0755 1096 500:245 root/bin/sync
f 0755 150584 500:245 root/bin/syscalltest
f 0755 51976 500:245 root/bin/telnetd
f 0755 2120 500:245 root/bin/touch
f 0755 58120 500:245 root/bin/traceroute
f 0755 1008 500:245 root/bin/true
f 0755 107144 500:245 root/bin/umount
f 0755 1892 500:245 root/bin/uname
f 0755 28256 500:245 root/bin/uuidgen
f 0755 5208 500:245 root/bin/wait
f 0755 20392 500:245 root/bin/which
f 0755 13304 500:245 root/bin/whoami
f 0755 1356 500:245 root/bin/yes
d 0700 800 500:245 root/dev
c 0644 5, 1 0:0 root/dev/console
c 0644 5, 64 0:0 root/dev/cua0
c 0644 1, 2 0:0 root/dev/kmem
c 0644 1, 1 0:0 root/dev/mem
b 0644 31, 2 0:0 root/dev/mtdblock2
c 0644 1, 3 0:0 root/dev/null
c 0644 2, 0 0:0 root/dev/ptyp0
c 0644 2, 1 0:0 root/dev/ptyp1
c 0644 2, 2 0:0 root/dev/ptyp2
c 0644 2, 3 0:0 root/dev/ptyp3
c 0644 2, 4 0:0 root/dev/ptyp4
c 0644 2, 5 0:0 root/dev/ptyp5
c 0644 2, 6 0:0 root/dev/ptyp6
c 0644 2, 7 0:0 root/dev/ptyp7
c 0644 2, 8 0:0 root/dev/ptyp8
c 0644 2, 9 0:0 root/dev/ptyp9
c 0644 2, 10 0:0 root/dev/ptypa
c 0644 2, 11 0:0 root/dev/ptypb
c 0644 2, 12 0:0 root/dev/ptypc
c 0644 2, 13 0:0 root/dev/ptypd
c 0644 2, 14 0:0 root/dev/ptype
c 0644 2, 15 0:0 root/dev/ptypf
c 0644 4, 0 0:0 root/dev/tty0
c 0644 4, 64 0:0 root/dev/ttyS0
c 0644 3, 0 0:0 root/dev/ttyp0
c 0644 3, 1 0:0 root/dev/ttyp1
c 0644 3, 2 0:0 root/dev/ttyp2
c 0644 3, 3 0:0 root/dev/ttyp3
c 0644 3, 4 0:0 root/dev/ttyp4
c 0644 3, 5 0:0 root/dev/ttyp5
c 0644 3, 6 0:0 root/dev/ttyp6
c 0644 3, 7 0:0 root/dev/ttyp7
c 0644 3, 8 0:0 root/dev/ttyp8
c 0644 3, 9 0:0 root/dev/ttyp9
c 0644 3, 10 0:0 root/dev/ttypa
c 0644 3, 11 0:0 root/dev/ttypb
c 0644 3, 12 0:0 root/dev/ttypc
c 0644 3, 13 0:0 root/dev/ttypd
c 0644 3, 14 0:0 root/dev/ttype
c 0644 3, 15 0:0 root/dev/ttypf
c 0644 1, 5 0:0 root/dev/zero
d 0700 268 500:245 root/etc
d 0775 20 500:245 root/etc/config
f 0664 8146 500:245 root/etc/config/boa.conf
f 0700 547 500:245 root/etc/group
f 0664 168 500:245 root/etc/inetd.conf
f 0664 185 500:245 root/etc/inittab
f 0664 47 500:245 root/etc/issue
f 0700 1552 500:245 root/etc/mime.types
f 0700 308 500:245 root/etc/passwd
f 0664 1193 500:245 root/etc/protocols
f 0664 231 500:245 root/etc/rc
f 0664 113 500:245 root/etc/services
f 0700 549 500:245 root/etc/shadow
f 0700 8 500:245 root/etc/shells
f 0700 12 500:245 root/etc/version
d 0755 36 500:245 root/home
d 0700 0 500:245 root/mnt
d 0700 0 500:245 root/proc
d 0700 36 500:245 root/sbin
f 0775 49316 500:245 root/sbin/init
f 0755 19396 500:245 root/sbin/testapp
d 0700 0 500:245 root/sys
d 0700 0 500:245 root/tmp
d 0700 0 500:245 root/usr
d 0700 0 500:245 root/var
--Scott
hi scott
here, romfs.bin ...,
i used nios IDE 5.0 and linux filesystem for generating rootfs folder.
i gave /<filesydstem project path >/target to mkcramfs for cramfs image.
but i can&#39;t get you. wher i have to writ and run int script.please tell me detail..please..............
