I am new to Quartus and Nios. I just installed the quartus II web edition 9.1 and nios II 9.1, and followed every step in NIOS II hardware development tutorial. When I used the NIOS II software build tools for eclipse to create a new Nios II application and bsp from template (I chose the count-binary template), I could not build the project with the following errors. I checked the template files, which have the right .h file included. Does anybody know what could be wrong? ---thanks
--------------------------------------------- make all Info: Building ../count_binary_bsp make --no-print-directory -C ../count_binary_bsp [BSP build complete] Info: Compiling count_binary.c to obj/count_binary.o nios2-elf-gcc -xc -MP -MMD -c -I../count_binary_bsp -I../count_binary_bsp/drivers/inc -I../count_binary_bsp/HAL/inc -DSYSTEM_BUS_WIDTH=32 -D__hal__ -pipe -DALT_NO_C_PLUS_PLUS -DALT_NO_INSTRUCTION_EMULATION -DALT_USE_SMALL_DRIVERS -DALT_SINGLE_THREADED -O0 -g -Wall -mno-hw-div -mhw-mul -mno-hw-mulx -o obj/count_binary.o count_binary.c Info: Linking count_binary.elf nios2-elf-g++ -T'../count_binary_bsp/linker.x' -msys-crt0='../count_binary_bsp/obj/HAL/src/crt0.o' -msys-lib=hal_bsp -L../count_binary_bsp -msmallc -Wl,-Map=count_binary.map -O0 -g -Wall -mno-hw-div -mhw-mul -mno-hw-mulx -o count_binary.elf obj/count_binary.o -lm obj/count_binary.o(.text+0x454): In function `main': /cygdrive/c/altera/91/nios2eds/examples/verilog/niosII_cycloneII_2c35/full_featured/software/count_binary/count_binary.c:352: undefined reference to `fopen' collect2: ld returned 1 exit status make: *** [count_binary.elf] Error 1Link Copied
You've got some code reduction options turned on. Only those examples which are tailored specifically for small code size will function with these options enabled. As you've discovered, count_binary is not one of these applications.
Cheers, - slacker- Mark as New
Thanks for your quick response.
Can you elaborate it a little more? How do you know I turned on "code reduction option" by looking at my errors? Where can I turn off this option?- Mark as New
--- Quote Start --- You've got some code reduction options turned on. Only those examples which are tailored specifically for small code size will function with these options enabled. As you've discovered, count_binary is not one of these applications. Cheers, - slacker --- Quote End --- Hi I have the same problems the guy above is having. My C code is quite small: #include <stdio.h> #include "system.h" #include <string.h> #include "altera_avalon_jtag_uart.h" #include "altera_avalon_jtag_uart_fd.h" #include "altera_avalon_jtag_uart_regs.h" int main() { char* msg = "Detected the character 't'.\n"; FILE* fp; char prompt = 0; fp = fopen ("/mnt/host/test.txt", "r+"); //Open file for reading and writing if (fp) { while (prompt != 'v') { // Loop until we receive a 'v'. prompt = getc(fp); // Get a character from the JTAG UART. if (prompt == 't') { // Print a message if character is 't'. fwrite (msg, strlen (msg), 1, fp); } if (ferror(fp))// Check if an error occurred with the file pointer clearerr(fp);// If so, clear it. } fprintf(fp, "Closing the JTAG UART file handle.\n"); fclose (fp); } return 0; } When I have "small_c_library" disabled I get these build error messages: nios2-elf-g++ -T'../epuisant_bsp/linker.x' -msys-crt0='../epuisant_bsp/obj/HAL/src/crt0.o' -msys-lib=hal_bsp -L../epuisant_bsp -Wl,-Map=epuisant.map -O0 -g -Wall -mno-hw-div -mhw-mul -mno-hw-mulx -o epuisant.elf obj/jtag.o -lm /cygdrive/c/altera/91/nios2eds/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.6/../../../../nios2-elf/bin/ld: region onchip_memory is full (epuisant.elf section .text). Region needs to be 1696 bytes larger. /cygdrive/c/altera/91/nios2eds/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.6/../../../../nios2-elf/bin/ld: section .rodata [02210020 -> 0221054b] overlaps section .exceptions [02210020 -> 022101c3] /cygdrive/c/altera/91/nios2eds/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.6/../../../../nios2-elf/bin/ld: section .rwdata [0221054c -> 02211fe7] overlaps section .text [022101c4 -> 0221c29f] /cygdrive/c/altera/91/nios2eds/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.6/../../../../nios2-elf/bin/ld: section .bss [02211fe8 -> 022120ef] overlaps section .text [022101c4 -> 0221c29f] collect2: ld returned 1 exit status make: *** [epuisant.elf] Error 1 But when I enable the "small_c_library" option I get these ones: obj/HAL/src/alt_uncached_free.o obj/HAL/src/alt_uncached_malloc.o obj/HAL/src/alt_unlink.o obj/HAL/src/alt_usleep.o obj/HAL/src/alt_wait.o obj/HAL/src/alt_write.o obj/HAL/src/altera_nios2_irq.o obj/HAL/src/crt0.o obj/alt_sys_init.o obj/drivers/src/altera_avalon_jtag_uart_fd.o obj/drivers/src/altera_avalon_jtag_uart_init.o obj/drivers/src/altera_avalon_jtag_uart_ioctl.o obj/drivers/src/altera_avalon_jtag_uart_read.o obj/drivers/src/altera_avalon_jtag_uart_write.o obj/drivers/src/altera_avalon_sysid.o obj/drivers/src/altera_hostfs.o [BSP build complete] Info: Compiling jtag.c to obj/jtag.o nios2-elf-gcc -xc -MP -MMD -c -I../epuisant_bsp -I../epuisant_bsp/drivers/inc -I../epuisant_bsp/HAL/inc -DSYSTEM_BUS_WIDTH=32 -D__hal__ -pipe -DALT_NO_C_PLUS_PLUS -DALT_NO_INSTRUCTION_EMULATION -DALT_SINGLE_THREADED -O0 -g -Wall -mno-hw-div -mhw-mul -mno-hw-mulx -o obj/jtag.o jtag.c Info: Linking epuisant.elf nios2-elf-g++ -T'../epuisant_bsp/linker.x' -msys-crt0='../epuisant_bsp/obj/HAL/src/crt0.o' -msys-lib=hal_bsp -L../epuisant_bsp -msmallc -Wl,-Map=epuisant.map -O0 -g -Wall -mno-hw-div -mhw-mul -mno-hw-mulx -o epuisant.elf obj/jtag.o -lm obj/jtag.o(.text+0x30): In function `main': /cygdrive/e/epuisant/software/epuisant/jtag.c:20: undefined reference to `fopen' obj/jtag.o(.text+0x54):/cygdrive/e/epuisant/software/epuisant/jtag.c:25: undefined reference to `getc' obj/jtag.o(.text+0x80):/cygdrive/e/epuisant/software/epuisant/jtag.c:28: undefined reference to `fwrite' obj/jtag.o(.text+0xc8):/cygdrive/e/epuisant/software/epuisant/jtag.c:34: undefined reference to `fclose' collect2: ld returned 1 exit status Could it be because of a small RAM memory? Should I just use a larger memory? I've followed all the instructions to create a file based system but nothing works.... Please help
--- Quote Start --- Region needs to be 1696 bytes larger. --- Quote End --- Yes, making the memory larger is one option. The other is to use alternate (smaller) stdio routines. There are examples (at least one) that show you how to do this. Cheers, slacker
Although your code is small, it uses a lot of the C runtime library ...
--- Quote Start --- Yes, making the memory larger is one option. The other is to use alternate (smaller) stdio routines. There are examples (at least one) that show you how to do this. Cheers, slacker --- Quote End --- Thanks for the quich reply, I'm grateful.
--- Quote Start --- Although your code is small, it uses a lot of the C runtime library ... --- Quote End --- Thanks for the quick reply. I'm grateful.
--- Quote Start --- Hi I have the same problems the guy above is having. My C code is quite small: #include
<stdio.h> #include
"system.h" #include
<string.h> #include
main() { char
* msg = "Detected the character 't'.\n"; FILE * fp; char
prompt = 0; fp = fopen ("/mnt/host/test.txt", "r+"); //Open file for reading and writing --- Quote End --- Hi, I wanted to ask you? where is the test.txt file in reference to your Nios II EDS build for Eclipse software? I am tryuing to read from a textfile, but I don't know where to put my text file? In the Project worskspace? or where? could someone help me please? Thank you
I am too facing this issue.
