use mac without using jtag
hi all,
i have a problem. on my 1c12 board i wanna use the mac without using the jtag. the mac only works after i start the terminal and the linux load up. it should work this way: reset -> access over telnet to the board.
does anyone know a solution for my problem??
thx http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/cool.gif
When you use the JTAG UART, the kernel is susspended until you open a nios2-terminal.
Search the forum t, there are a few posts that tell you how to fix this problem by disabling the JTAG UART in the Kernel and then enabling/using the Serial UART.
Hope this helps.
