using IRQ
I would like know:
-what is the function when I use sopc and nios
-how I manage IRQ
-how I program the IRQ
For now, I has just found that it's in many file in sopc. But when it interrupt ???? Why it interrupt and when he restart ??
Thanks for you help
It depends on the operating system you run your software on. If you use ucOS or the Altera HAL, have a look at the hal api (http://www.altera.com/literature/hb/nios2/n2sw_nii52010.pdf).
The alt_ic_* functions are used to manage IRQ's and ISR's
I have altera HAL.
When I look a lot file on HAL/inc/priv I have "alt_iic_isr_register.h" and "alt_irq_table.h" but there are nothing inside.
For information it's teh first for me to work with SOPC and NIOS
The HAL API document is better to find information about the functions.
What exactly are you looking for? You can know the compenents that generate interrupts from SOPC builder. When you build your bsp, the generated system.h file will contain constants with the vector numbers for all your interrupts.
Write your own isr, and use the register function to associate it with the interrupt you want to process.
