Hello all,
Does anyone have an idea how to make sure the usleep() fonction is accurate. Whatever values I set usleep() to (which is in the range of 3 to 50), the resulting pause is in the range of 50 to 100us respectively. Thanks, ericLink Copied
What Quartus version are u using? (Quartus 4.1 without service pack, had some problems with counters synthesys).
Furthermore check the timer setting in SOPC (the timer u set in IDE as system timer...), set full featured option...- Mark as New
Hello Soin,
I am using Quartus 4.2, SP1 (build 178), with NIOS II IDE version 1.1.0, build 137. BTW, I haven't been on the bench yet. I am looking at my simulation and see that accesses to certain of my regsiter file are not following the usleep() command. I am running very simple code, just accessing custom register which have their accesses interleaved with usleep() commands. I need accuracy since all my code is based on usleep() as I am driving a one-wire interface. Here is trial piece of code: IOWR_32DIRECT(REGSECT_DGL_0_BASE,0x88,0xBEEF0000); usleep(12); IOWR_32DIRECT(REGSECT_DGL_0_BASE,0x88,0xBEEF1111); usleep(3); IOWR_32DIRECT(REGSECT_DGL_0_BASE,0x88,0xBEEF1112); usleep(50); IOWR_32DIRECT(REGSECT_DGL_0_BASE,0x88,0xBEEF1113); usleep(80); Thanks, Eric- Mark as New
What type of Nios II processor (e,s,f) r u using and at what clock frequency?
I am using the /e at 66MHz
In this case u will have a "up to 9 DMIPS processor", one instruction each 0.1 us. Perhaps this is critical in the execution of usleep() function...
Hello Soin,
I tried the /s, but did not help much....until i figured I was simulating in "debug" mode instead of the "release" mode. Last sim in "release" mode this time with /s showed relatively good accuracy: ask 3-> got 4.3, 12->13.75 and 50 -> 50.85. I will try with the /e... I also tried in the meantime with the alt_timestamp() family of functions which would have been an avenue to create my own my_usleep() function, but since a few calls are required each time, they are not so accurate unless you take into consideration the time for the call to alt_timestamp_start() and alt_timestamp() to elapse. But in that case, since comparisons are involved, I guess I would have obtained better result having the data cache with the /f (haven't tried). Thank you very much for your hints. It helped a lot. Regards, Eric- Mark as New
Hello eboisver,
reading your last post, i've got another idea: you can try to put -03 optimization level in the project and associated library properties. I think it could be a compilation problem...![](/skins/images/FCBE28625AAD2D8AF3EB3F393BF39703/responsive_peak/images/icon_anonymous_message.png)
Topic Options
