12745 Discussions
uuid.h/luuid problem, please help
sory for annoying topic, but i've tried all possible solutions in the forum.
After ./update I cannot compile a simple kernel.
First i recieved a uuid.h not found error during compilation.
I made a research and found that the problem was in the absence of uuid-devel package, so I reinstalled it. But this hasn't helped.
So i found uuid.h file in /usr/include and put it in the required directory under ../uClinux-dist/user/mtd-utils/.../include/uuid/ and the error gone, but another one has come up:
CHK include/version.h LD mkfs.ubifs/mkfs.ubifs /usr/bin/ld: cannot find -luuid collect2: ld returned 1 exit status make: *** Error 1 make: Leaving directory `/home/Vasek/linux_tools/nios2-linux/uClinux-dist/user/mtd-utils/36d8de81049c9c908740b690c664b5bd3703ccd6' make: *** Error 2 make: Leaving directory `/home/Vasek/linux_tools/nios2-linux/uClinux-dist/user/mtd-utils' make: *** Error 2 make: Leaving directory `/home/Vasek/linux_tools/nios2-linux/uClinux-dist/user' make: *** Error 2 make: Leaving directory `/home/Vasek/linux_tools/nios2-linux/uClinux-dist/user' make: *** Error 1
I'm at the unstable-nios2mmu branch in linux-2.6 and at trunk in uClinux-dist.
Please, help. What am I doing wrong?
CHK include/version.h LD mkfs.ubifs/mkfs.ubifs /usr/bin/ld: cannot find -luuid The linker says "I searched the library 'libuuid.a' or 'libuuid.so', but I couldn't find it".
So please try
Library Configuration ---> <select>
--- *** Additional Blackfin dist libs ***
[ ] Build dmalloc
[* ] Build e2fsprogs-libs
[ ] Build eXosip
Kazu
Hi Kazu,
thank you very much for your help.
Actually I haven't tried your solution, but switching to the nios2 branch (i was at unstable-nios2mmu before), updating and reinstalling e2fsprogs-devel package did the job.
Thanks again.
Now I can move forward.
