vmlinux OR vmlinux
Hi hippo,
in ~/linux-2.6.x/ I find a 12.8 MB vmlinux file
in ~/linux-2.6.x/arch/nios2nommu/boot/cmpressed/ I find another vmlinux file with only 1 MB.
Could you please explain the difference between those two files ?
--- Quote Start ---
originally posted by mfm@May 12 2006, 09:26 AM
hi hippo,
in ~/linux-2.6.x/ i find a 12.8 mb vmlinux file
in ~/linux-2.6.x/arch/nios2nommu/boot/cmpressed/ i find another vmlinux file with only 1 mb.
could you please explain the difference between those two files ?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15304)
--- quote end ---
--- Quote End ---
The zImage uncompress loader is actually a reduced linux to call kernel library.
So it is small, only less thtan 10K bytes of binary.
Don&#39;t be confused on the file size. The ELF is large becuase it can contain a lot of debug symbols. You can reduce the ELF size by remove all the debug symbols, with "nios2-linux-uclibc-strip" command.
You should use binary to mkimge, not elf.
But why don&#39;t you follow step6 to run zImage right after you built the kernel?
It looked like you skipped the basic steps and got confused.
You jumped start on u-boot too early.
There are two elf after you make zImage,
linux-2.6.x/vmlinux the orignal kernel elf, load adress = sdram start
linux-2.6.x/arch/nios2nommu/boot/zImage the compressed kernel elf, load address = sdram start + boot link offset
Look at kernel dir include/nios2_system.h to find out the address map.
