12745 Discussions
what is the nios2 linux telnetd password?
hi:
I run telned on my dvb, but I login fail, reson is" invalid password"
In hippo guide:
The password files are etc/passwd,etc/group,etc/shadow .
But I don't understand it. Who can explain how to get the tlenetd user name and
password?
thanks a lot.
hi,
I think it's the same passwd as nios2terminal :
username = nios
passwd = uClinux
this is what I use, and it runs with this configuration http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
--- Quote Start ---
originally posted by sdhnain@May 16 2006, 08:26 AM
hi,
i think it&#39;s the same passwd as nios2terminal :
username = nios
passwd = uclinux
this is what i use, and it runs with this configuration  http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/smile.gif
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15400)
--- quote end ---
--- Quote End ---
Thanks you reply
I have already use it,but return invalid password
Study by "man login" &#39;man telnetd", and "man passwd".
http://www.tldp.org/howto/shadow-password-howto.html (http://www.tldp.org/howto/shadow-password-howto.html) .
We use the login in busybox.
But mx140 use hardcoded password in their login.
Hi Alex824,
Please build inetd and telnetd in uClinux-dist.
telnetd should not start standalone, as "telnetd &".
it should be invoked by inetd , adding a line in etc/inetd.conf .
Please use "addgroup","adduser","passwd" to create password on nios2.
Then update the password files in ~/rootfs.
Add ptyp0-9 to , or remove the file etc/securetty, if you want root login on telnetd.
