what is the problem.......?
2004.11.09 16:12:41 (*) Building system_ram_contents.srec using "build"
# 2004.11.09 16:12:41 (*) cd F:/kdj/adtb2_cyclone/IF_single_flash/040927_3.1IF_single_4.1 ; nios-build --sdk_directory=F:/kdj/adtb2_cyclone/IF_single_flash/040927_3.1IF_single_4.1/nios_cpu_sdk -s -o system_ram_contents.srec -b 0 nios_cpu_sdk/src/main2.c
nios_cpu_sdk/src/main2.c.o: In function `main':
nios_cpu_sdk/src/main2.c.o(.text+0xa0): undefined reference to `mytimerISR'
nios_cpu_sdk/src/main2.c.o(.text+0xa2): undefined reference to `mytimerISR'
nios_cpu_sdk/src/main2.c.o(.text+0xa4): undefined reference to `mytimerISR'
nios_cpu_sdk/src/main2.c.o(.text+0xa6): undefined reference to `mytimerISR'
# ## nios-build error: last system call returned256
# ## (Perhaps you need ".global _start" and "start:")
Died at - line 85.#
# 2004.11.09 16:12:46 mk_custom_sdk: WARNING
# 256 cd F:/kdj/adtb2_cyclone/IF_single_flash/040927_3.1IF_single_4.1 ; nios-build --sdk_directory=F:/kdj/adtb2_cyclone/IF_single_flash/040927_3.1IF_single_4.1/nios_cpu_sdk -s -o system_ram_contents.srec -b 0 nios_cpu_sdk/src/main2.c
ERROR: Could not build Peripheral Contents for nios_cpu
Error in processing. System NOT successfully generated.
mytimerISR is the function name of timer interruption.it's contained in the program.
what's the meaning??????
thx
faint boy
If possible can you give a code sample that uses the timer (and more info on the system itself).
If I don't get back to you soon just email me and I'll be a bit faster (email address is in my profile)
