12746 Discussions
where is the function "elca_findfirst()'?
Everyone,
I want to compile the picture viewer using the Eclipse GUI,but such functions can never be referenced (elca_findfirst(), elca_......).They are not in the BSP generated by the Eclipse.
What should I do? Must I use the command line to create this project?:rolleyes:
Thanks in advance
I have seen in the file"elca_fat.h" there are definations:
extern unsigned char elca_findfirst(void);
But there are no head files included in this file.That is really wired.Where are these functions?
someone helps me.....
I think some beginners could meet the same problem with me.....
Right. Hunt for libelca_fat.a. It's a 3rd party library and IP for FAT and SD Card access...no source code provided.
--slacker
--- Quote Start ---
--slacker
--- Quote End ---
OK.I see. Thank you so much .So I think there is no way to use the GUI because there is no source file. I can only use the command line. That's really not very convinent.:mad:
I wouldn't know/care. I only use GUIs for debug...
--- Quote Start ---
--- Quote End ---
Yeah.I think probably the command shell is more powerful.Anyway thank you for your hint:D
