Good afternoon,
I'm interesting about Linux on FPGA but I haven't knowledge about this subject. Can you tell me witch FPGA is adapted for Linux ? I'm working with Cyclone. Is it sufficient ? Thanks a lot EtienneLink Copied
If you have a Cyclone, you can try the Nios II Linux distribution which is available from these forums. You'll need to build a hardware design for your Cyclone FPGA that has flash, memory, and a non-fixed period timer. A UART (preferrably JTAG for now) would be useful as well.
Take a look at the "standard" quartus project for an idea. Linux will compile and run for the "standard" quartus project.
