hello,
after i configure the kernel (steps in http://nioswiki.com/linux/linux_quick_start) i arrived to this step Connect USB Blaster cable to 3C120 dev board, download the sof and elf. nios2-configure-sof ../3c120_default/nios2_linux_3c120_125mhz_top.sof nios2-download -g images/linux.initramfs.gz nios2-terminal the problem i have 2c35 board the you think it will be work or no if no there is any solution ?Link Copied
