write & read SDRAM chip
hi all
I try to read and write the external 8M SDRAM chip.
At the Nios II IDE, my system library and "Linker Script" with program memory(.text), Read-only data memory(.rodata), Read/Write data memory (.rwdata), Heap memory, Stack memory all setting another RAM chip "sram_0".
My program is below:
# include <stdio.h># include <alt_types.h># include <io.h># include <system.h># include <string.h># include "system.h"
int main(void)
unsigned int value = 0;
unsigned int pattern = 0x10;
unsigned int i, memory_size;
memory_size = 0x800;
//SDRAM actual size is 0x7FFFFF
for(i = 0; i< memory_size; i=i+0x10)
IOWR_16DIRECT((SDRAM_0_BASE), i, pattern);
value = IORD_16DIRECT((SDRAM_0_BASE), i);
printf("%d,%d\n", i,value);
return 0;
but in the Console with result is only display 6 data:
0,16
16,16
32,16
48,16
64,16
80,16
Could anyone tell me where it is fault ?
At the SOPC Builder->More Settings->Exception Address & Memodule my setting is sdram_0. is this need change to sram_0 or not ? http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/blink.gif
You&#39;ve answered it, yourself. You&#39;re writing over the code at your Exception Address (starting at offset 0x20) in your SDRAM.
Cheers,
- slacker
--- Quote Start ---
originally posted by slacker@Jun 2 2006, 12:02 AM
you&#39;ve answered it, yourself.  you&#39;re writing over the code at your exception address (starting at offset 0x20) in your sdram.
cheers,
- slacker
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15784)
--- quote end ---
--- Quote End ---
hi slacker
The problem has already been solved
thanks for your reply
--- Quote Start ---
originally posted by suway1219+jun 2 2006, 02:00 am--><div class='quotetop'>quote (suway1219 @ jun 2 2006, 02:00 am)</div>
--- quote start ---
<!--quotebegin-slacker@Jun 2 2006, 12:02 AM
cheers,
- slacker
--- quote end ---
--- Quote End ---
hi slacker
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15785)</div>
[/b]
--- Quote End ---
Hi,suway1219
I will write and read data from SDRAM. so, can you give a complete example?
thx again.
Faye
