I prepared some zImage for dev boards with buildroot tools.
They use minimal config ~/download/kernel.config . To use, open the quartus II project, and download sof to your board. for altera nios II dev boads, altera/kits/nios2/examples/verilog/ eg. niosII_stratix_1s10/standard/standard.sof for DE2, DE2_System/DE2_demonstrations/DE2_NET/DE2_NET.sof Then, open a sdk shell window, with Start-->Programs-->Altera-->Nios II 5.1-->Nios II SDK Shell nios2-download -g zImage nios2-terminal http://hungryhippo.myweb.hinet.net/zimage_de2_net (http://hungryhippo.myweb.hinet.net/zimage_de2_net) http://hungryhippo.myweb.hinet.net/zimage_std_1c12 (http://hungryhippo.myweb.hinet.net/zimage_std_1c12) http://hungryhippo.myweb.hinet.net/zimage_std_1s10 (http://hungryhippo.myweb.hinet.net/zimage_std_1s10) http://hungryhippo.myweb.hinet.net/zimage_std_2c35 (http://hungryhippo.myweb.hinet.net/zimage_std_2c35) http://hungryhippo.myweb.hinet.net/zimage_full_1s40 (http://hungryhippo.myweb.hinet.net/zimage_full_1s40) http://hungryhippo.myweb.hinet.net/zimage_std_1c20 (http://hungryhippo.myweb.hinet.net/zimage_std_1c20) http://hungryhippo.myweb.hinet.net/zimage_std_1s40 (http://hungryhippo.myweb.hinet.net/zimage_std_1s40) http://hungryhippo.myweb.hinet.net/zimage_std_2s60 (http://hungryhippo.myweb.hinet.net/zimage_std_2s60) or find them on Jhdar's site, (thanks a lot to his help) http://via.fps-tech.org/snapshots/nios2/ (http://via.fps-tech.org/snapshots/nios2/) for 2s60es and 1s10es, use 2s60 and 1s10es 's zImage. Hope these will help. PS. Please let me know if the updated link work or not?Link Copied
--- Quote Start --- originally posted by hippo@May 7 2006, 03:52 AM i prepared some zimage for dev boards with buildroot tools.
they use minimal config ~/download/kernel.config .
to use, open the quartus ii project, and download sof to your board.
for altera nios ii dev boads, altera/kits/nios2/examples/verilog/
eg. niosii_stratix_1s10/standard/standard.sof
for de2, de2_system/de2_demonstrations/de2_net/de2_net.sof
then, open a sdk shell window, with start-->programs-->altera-->nios ii 5.1-->nios ii sdk shell
nios2-download -g zimage
nios2-terminal
http://hungryhippo.jot.com/wikihome/zimage_std_1s10 (http://hungryhippo.jot.com/wikihome/zimage_std_1s10)
http://hungryhippo.jot.com/wikihome/zimage_std_1s40 (http://hungryhippo.jot.com/wikihome/zimage_std_1s40)
http://hungryhippo.jot.com/wikihome/zimage_full_1s40 (http://hungryhippo.jot.com/wikihome/zimage_full_1s40)
http://hungryhippo.jot.com/wikihome/zimage_std_2c35 (http://hungryhippo.jot.com/wikihome/zimage_std_2c35)
http://hungryhippo.jot.com/wikihome/zimage_de2_net (http://hungryhippo.jot.com/wikihome/zimage_de2_net)
http://hungryhippo.jot.com/wikihome/zimage_std_1c12 (http://hungryhippo.jot.com/wikihome/zimage_std_1c12)
http://hungryhippo.jot.com/wikihome/zimage_std_1c20 (http://hungryhippo.jot.com/wikihome/zimage_std_1c20)
http://hungryhippo.jot.com/wikihome/zimage_std_2s60 (http://hungryhippo.jot.com/wikihome/zimage_std_2s60)
for 2s60es and 1s10es, use 2s60 and 1s10es 's zimage.
hope these will help.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15136)
--- quote end ---
--- Quote End --- Hi hippo, all those links need to sign in with user name and password !
Hi hippo,
I noticed that the zImage files are compressed in a gz format, is that possible to do so with a bz2 format since the last seems more size efficient.- Mark as New
--- Quote Start --- originally posted by mfm@May 8 2006, 06:23 AM hi hippo,
i noticed that the zimage files are compressed in a gz format, is that possible to do so with a bz2 format since the last seems more size efficient.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15161)
--- quote end ---
--- Quote End --- Those are elf, and to be used directly to nios2-download. The uncompress loader uses gz format internally, because there is a build-in gunzip inside the kernel library. It is possible to use bz2, but that would require adding the bunzip2 to the loader.
--- Quote Start --- originally posted by hippo+may 8 2006, 03:14 am--><div class='quotetop'>quote (hippo @ may 8 2006, 03:14 am)</div>
--- quote start ---
<!--quotebegin-mfm@May 8 2006, 06:23 AM hi hippo,
--- quote end ---
--- Quote End --- Those are elf, and to be used directly to nios2-download. The uncompress loader uses gz format internally, because there is a build-in gunzip inside the kernel library. It is possible to use bz2, but that would require adding the bunzip2 to the loader. <div align='right'><{post_snapback}> (index.php?act=findpost&pid=15163)</div> [/b] --- Quote End --- I noticed in the compressed directory the files vmlinux.bin and vmlinux.gz, so I concluded that you compress the bin with gz before transforming to a zImage, so my question wasis that possible to do so but with bz2 format, and how.
TO_BE_DONE
