OpenCL* for CPU
Breakpoints not working in VS2013
Max_B_
This is very similar to an issue I ran into a while ago (in which I was using VS2012 rather than 2013), which turned out to be caused by (silently!) incompatible versions of Intel's OpenCL runtime, and SDK.
I have attached screenshots showing the problem, using Intel's own 'MedianFilter' example project (trivially modified with a printf).
The breakpoints show the solid red circles which indicate that they are properly bound, yet they do not work.
I am using:
Visual Studio 2013 Ultimate.
Windows 7, 64-bit.
OpenCL runtime for Intel Core and Xeon Processors [...] version 4.5.0.8 [the latest release]
Intel SDK for OpenCL Applications 2014 version 4.6.0.92 [the latest release]
Max_B_
Just realised I may have forgotten the -g -s flags. I'll check tomorrow.
(If so, I've improperly reduced my 'real problem' in my (non-example) codebase).
Max_B_
Have since added the  -g -s  flags, as shown in attached image.
Breakpoints still do not work.
I will try rolling back to Visual Studio 2012.
Max_B_
Solved the problem: the MedianFilter example uses offsets, so my work-item (0,0,0) debugging session wasn't applicable.
Using (0,2,0), it works, in both VS2012 and VS2013. (By means of Right click > Options > Select Work Items.)
I'll now get back to trying to debug my own project...
