OpenCL* for CPU
Ask questions and share information on Intel® SDK for OpenCL™ Applications and OpenCL™ implementations for Intel® CPU.
This forum covers OpenCL* for CPU only. OpenCL* for GPU questions can be asked in the GPU Compute Software forum. Intel® FPGA SDK for OpenCL™ questions can be ask in the FPGA Intel® High Level Design forum.
1745 Discussions
Bug in OpenCL driver on Intel HD Graphics?
Alexander_Karsakov
Hello.
I found a curious bug in Intel OpenCL driver on Intel HD Graphics 4600 (Core i5 4570).
Driver version: 10.18.10.3412
Intel OpenCL SDK Version: 2013 R3 64-bit
I write following kernel:
    int gidx = get_global_id(0);
    int gidy = get_global_id(1);
    __local uchar temp[3];
    uchar r = 255;
    if (gidx == 0 && gidy == 0)
        temp[0] = 255;
        temp[1] = 34;
        temp[2] = 255;
        for (int i=0; i<3; i++)
            printf("temp = %d\n", temp);
            printf("r = %d\n", r);
            r = min(r,temp);
When I run it I get:
temp = 255
r = 255
temp = 34
r = 15
temp = 255
r = 15
Variable 'r' have incorrect value (15 instead 34). What may cause the problem?
Raghupathi_M_Intel
I tried reproducing this on a newer driver as well as the driver you mentioned without success. I am using the 2014 SDK though, but I do believe that this wont make any difference.
Is the code you posted the whole kernel or part of a bigger kernel? If its latter, then I suspect the bug is else where in your code.
Raghu
Alexander_Karsakov
This code is the whole kernel. This is simplified case from Erode function in OpenCV library. And it correct works on other platforms (Nvidia, AMD, Intel CPU).
If I define:
#define OP_MIN((A),(B)) (A) < (B) ? (A) : (B)
and replace min() for OP_MIN this example gives correct result (include Intel GPU), but works a little slower.
I will try to install new version of Intel OpenCL SDK to check it.
Alexander_Karsakov
Another strange detail: this error occurs only with min() function.
Similar example with max() works correct:
    uchar r = 0;
        temp[0] = 0;
        temp[1] = 34;
        temp[2] = 0;
            r = max(r,temp);
Alexander_Karsakov
Hi Raghu.
I checked this code with Intel OpenCL SDK Version 2014. And this error still occurs for me.
What do you suggest for solving this issue?
Alexander.
Alexander_Karsakov
Hi Raghu.
I still wait for your response. If it can help, here is a link to the original code of 'erode' function from OpenCV library - https://github.com/Itseez/opencv/blob/master/modules/imgproc/src/opencl/morph.cl
Alexander.
Raghupathi_M_Intel
Hi Alexander,
Did you update the driver or are you still using 10.18.10.3412?
Raghu
Raghupathi_M_Intel
Hi Alexander,
I retested this on another driver and was able to reproduce the behavior you are seeing. I will open a bug and let you know when the fix is in.
Raghu
Raghupathi_M_Intel
After further debugging, looks like r gets truncated to 4 bits. This issue is fixed/not reproducible in the internal drivers. I dont have any info on when the next driver will be posted, but I'll keep you updated.
Raghu
Alexander_Karsakov
Hi Raghu,
I updated to the latest beta driver (10.18.10.3496).
Thanks for your help!
Alexander.
