OpenCL* for CPU
Ask questions and share information on Intel® SDK for OpenCL™ Applications and OpenCL™ implementations for Intel® CPU.
This forum covers OpenCL* for CPU only. OpenCL* for GPU questions can be asked in the GPU Compute Software forum. Intel® FPGA SDK for OpenCL™ questions can be ask in the FPGA Intel® High Level Design forum.
1745 Discussions
Can't get GPU Device on IvyBridge platform
yangjin149
I am using IvyBridge platform, and have installed the Latest OpenCL SDK 2012. But in my helloworkd opencl programme. I can only get CPU Device while can't get GPU Device. My OS is windows 7 64bit. Below are some informations(platform, extension, etc)I printed when run my program:
FULL_PROFILE index.html:112
OpenCL 1.1 index.html:114
Intel OpenCL index.html:116
Intel Corporation index.html:118
cl_khr_fp64 cl_khr_icd cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_byte_addressable_store cl_intel_printf cl_ext_device_fission cl_intel_exec_by_local_thread cl_khr_gl_sharing cl_intel_dx9_media_sharing index.html:120
Intel Core i7-3720QM CPU @ 2.60GHz index.html:135
Intel Corporation index.html:137
OpenCL 1.1 (Build 31360.31441)
I used different way of sample to get device. Firstly I got a platform, and then got device like this:
clGetDeviceIDs(platform_id, CL_DEVICE_TYPE_GPU, 1, NULL, &num_devices);
It works for CPU but not GPU.
My graphics driver is the latestest with HD4000. Anyone can help on this? Thanks
Jin
Raghupathi_M_Intel
Hi Jin,
You should be able to get both the CPU and GPU devices on IvyBridge with HD4000. What error message are you getting trying to get the device? Can you post your sample code here?
Raghu
Mikhail_Smirnov
Hello Jin,
In other topics it is discussed that your monitor should be connected toHD4000, otherwise it is disabled. May be this is the isuue.
Sorry to interrupt, but i'm also interested in HD4000 OpenCL issue and currently reading all topics connected:)
