OpenCL* for CPU
Ask questions and share information on Intel® SDK for OpenCL™ Applications and OpenCL™ implementations for Intel® CPU.
This forum covers OpenCL* for CPU only. OpenCL* for GPU questions can be asked in the GPU Compute Software forum. Intel® FPGA SDK for OpenCL™ questions can be ask in the FPGA Intel® High Level Design forum.
1745 Discussions
Does __attribute__((packed)) works correctly ?
Polar01
I'm facing a problem, I have the following structure :
typedef struct __attribute__((packed))
float Ks;
clSpectrum Cs;
float exponent;
} ShaderParam_plastic;
But when I convert it to :
float Kd;
clSpectrum Cd;
float Ks;
clSpectrum Cs;
float exponent;
I got a crash ! I have checked for the data I send and they are aligned correctly !
In fact I use this structure :
unsigned int shaderId;
union __attribute__((packed))
ShaderParam_emitter emitter;
ShaderParam_glass glass;
ShaderParam_matte matte;
ShaderParam_mirror mirror;
ShaderParam_plastic plastic;
ShaderParam_Textured_emitter Textured_emitter;
ShaderParam_Textured_glass Textured_glass;
ShaderParam_Textured_matte Textured_matte;
ShaderParam_Textured_mirror Textured_mirror;
ShaderParam_transmissive transmissive;
} params;
} ShaderParameters;
Even my union is aligned !!! If the syntax is correct ?
Polar01
In the OpenCL spec. page 199, they wrote this :
"You may only specify this attribute on the definition of a enum, struct orunion, not on a typedef which does not also define the enumerated type,structure or union."
Does it mean that I cannot pack a "typedef" ? or that I can write :
typedef struct__attribute__((packed)) MyStruct {...};
But not ?
typedef__attribute__((packed))struct MyStruct {...};
NB:I have replace my typedef with a struct, but it still crash !!!
NB2: I cannot use "align" because my OpenCL code is generated at run-time. So, it is difficult to do and error prone :-P (Also, my buffer is generated from a malloc, then filled at run-time with memcpy !!)
Polar01
Even with this version of my code ... my soft still got a crash !!!
[cpp]struct __attribute__((packed)) ShaderParam_transmissive
float Ks __attribute__((packed));
clSpectrum Cs __attribute__((packed));
float eta __attribute__((packed));
struct __attribute__((packed)) ShaderParametersStruct
uint shaderId __attribute__((packed));
struct ShaderParam_emitter emitter;
struct ShaderParam_glass glass;
struct ShaderParam_matte matte;
struct ShaderParam_matte_rough matte_rough;
struct ShaderParam_mirror mirror;
struct ShaderParam_plastic plastic;
struct ShaderParam_Textured_emitter Textured_emitter;
struct ShaderParam_Textured_glass Textured_glass;
struct ShaderParam_Textured_matte Textured_matte;
struct ShaderParam_Textured_mirror Textured_mirror;
struct ShaderParam_transmissive transmissive;
} __attribute__((packed)) params __attribute__((packed));
};[/cpp]
Guy_B_Intel
Thanks for your post.
There is a documented known issue in the current SDK, which prevents the usage of user defined structures as arguments for kernels. This issue might be solved by passing these structures in OpenCL memory objects.
If the bare definition of a packed structure fails, please letme know, soI can file a bug on this issue.
Guy
Polar01
In my kernel I use this :
__kernel void __attribute__((vec_type_hint(float4))) RenderPath(
__constantchar* shaderParametersBuffer
and later I access it like this :
ShaderParameters shaderParams = *((__constantShaderParameters*)(shaderParametersBuffer + offset));
where 'offset' is defined in bytes !!!
So, maybe it is not related to this issue ?
Polar01
Can you enter a new bug please ? It sounds unrelated ! Or maybe you have a solution !
Polar01
Can I have any news or help please ?
I'm still trying to fix it, but if the problem come from the SDK I just have to help you to fix it :-P
Thanks a lot
Guy_B_Intel
Thanks again for your post.
It's an interesting issue, apparently it's a bug in our SDK. I'll open a bug report about this issue.
We'll let you know about any progress.
Guy Benyei
Polar01
Thanks a lot Guy,
I can provide you my application if necessary (if Intel agree to sign a Non Disclosure Agreement of course).
You can contact me on my email.
Regards and thanks for your work
Krys
Shiri_M_Intel
Hi
Is it possible to create simple kernel, not full application that cause the same failure?
This can elimiminate the need to involve legal.
Thanks, SHiri
ARNON_P_Intel
Right Shiri,
Krys, in addition, I encourage you to join The Intel Visual Adrenaline Software Development Program. Log into the program site and see our community and suooirt offering to visual computing developers.
As this product is in preview stage, support through forum is what we offer. Looking forward, we will work to expand our support offering to provide you the level that you need.
Arnon
Polar01
I will take a look at your program, thanks for the information.
I have test the new SDK and everything works perfectly !! :-D and even faster.
Congratulation for your release... good job :-)
So, is it possible to be in touch with a "project manager" in order to discuss some "marketing stuffs" ?
